Hi, My micra has had this what used to be a little issue of it not running on all 4 for a little time, it would do it for a couple of seconds only and work normally again, but today it hasn't ran on 4 at all, I can't really (and I shouldn't I assume?) drive it since it's 1. VERY embarassing since it sounds exactly like a moped car, 2. It perfoms like one too. It CAN be driven tho.
I recorded this probably useless thing to demonstrate how it sounds exactly: http://vocaroo.com/i/s1LDQ2sIxyEO
It did this when I bought it, I did know it had this issue, I changed the spark plugs little after I bought it, but the problem (running on 3(?)) didn't stop.
So what else could be causing this, is my micra basically dead or can anything be done? I tried giving it high rpm's, since that helped when it did this before, but now it won't run on 4 at all.
E: Just now I found this article, should I try the advice it gives? (testing if one of the plugs isn't firing) http://wiki.answers.com/Q/What_is_it_when_a_4_cylinder_car_is_running_on_3_cylinders?#slide=1
