So if I’m driving along my car will cut out for a second not even that and flash the check engine light once not even enough for it to fully light up , however sometimes it will flash constantly and the car will stall and I will have to turn the key off for 30 sec then it will start fine , I was over fuelling I managed to read the code and it was maf code so I changed the maf , plugs and 02 sensor , it was running fine for abit but now it’s went back to the same anyone got any ideas maybe a ,dodgy injector ? Also just a note when I try and get codes now it’s simply coming back as 55 (no fault)
