1.3 cams
Just a thought, does it matter if they are from a dizzy or a coil pack?
afaik fitting dizzy cams into coilpack head, it doesn't matter cos the cam lobe/sprocket timing prob the same and the un-used dizzy area of the head/cover is closed off (cam timing is taken from the timing chain sprocket end).
obviously when fitting different cams you'll need to check & adjust the cam-valve shim clearances.
can someone or Frank verify 1.3 preface dizzy cams work on coilpack 1L heads?
Any one got a set of 1.3 cams for sale for a k11 1996 car. Also is there a step by step guide on fitting them. Any help is welcome. Thanks.
