Hi, all! I min process of swapping 1.3 cams into my 1l engine and already make full bunch of mistakes.(just found guide how to do it).
Main problem is what that I cant put the chain back and timing. The chain just refuse to go back on the sprockets and it seems like it has to much load despite I took the tensioner off. And timing is the other problem as rotate inlet cam with spanner to set pointer on second (tdc)position. Also mark on idler sprocket is not on male, but female link and I cant change it, as part of engine casting on the bottom just preventing from doing so.
Will appreciate of your help, as just serviced my micra with new clutch, brakes, oils, joints etc. Wife will go crazy if Ill scrap it now due to not running engine.
