1.3 cams in a 1.0l (and 1.6 injectors)
Harlen
Dr. Zoidberg
Site Supporter
Hey all, I read that some people have put 1.3 cams in a 1.0l and found it a good mod. Anyway, I bought some 1.3 cams to put in my 1l and was wondering if 1.6 (ga16) injectors would be a good mod to go with them?
I'm currently running a fuel pressure regulator and induction kit on it and didn't know whether i would need bigger injectors to increase fuel flow more. Are 1.3 injectors worth doing or are they identical?
Thanks in advance.
1.0 and 1.3 injectors are the same, although according to Nissan F.A.S.T i think they may have a different part number. There's plenty of headroom in the 1.3 injectors to hold you for the usual upgrades including a full exhaust system, induction mods and 1.3 cams. The standard cars just about manage 50% duty at peak torque on a standard engine, so you'll be fine even though you're revving higher to make power.
fwn Yea would any electronic editing, or any other adjustments/mods be required after a 1.0 to 1.3 camshaft upgrade? (Y)
