Hi new to this iv a tarmac oval track 1l micra that I wanna put in the 1300 cams and also advance the cam timing.. please and information would be brill..
"Hi new to this iv a tarmac oval track 1l micra that I wanna put in the 1300 cams and also advance the cam timing.. please and information would be brill..
advancing the cams only suits a daily driver sean, it basically corrects the slack from the worn chains and restores the lowdown grunt that the car had when it left the factory,
yours will be ragged around an oval at higher rpm than that
Thanks frank another question for u... The 1.0 coil pack engine have more bhp but same block and head as the dizzy model where are they pulling the extra power from??? And also when I fit 1300 cams is the timing marks the same a 1.0l marks?? Thanks for getting back to me lads
there are some different pinouts on the pre-nats and nats2/5 ecu,s sean, there are some wiring diags about
and the coilpack (post 2000) bosch motronic setup is totally different
