1.2 thermostat housing,
You can find cheaper aftermarket thermostat housing. The Nissan parts are expensive.
That thermostat can cause high fuel consumption, if you can believe this.
No errors if you test the car, but the sensor tells ECU that engine is cold, and needs more petrol to burn.
Find a cheap one and replace
