1.2 Suntop Restoration by PP7
porkpie700
Buy & Sell Member
In March 2011 I had a moment of madness and bought this 1991 1.2 GS Suntop.
Andso, much work began...
Like replacing this death-trap fuel filler neck.
Some welding and treating...
Brand new brake disks and pads. New trackrod ends, wishbones, wheel bearings and suspention (shocks, springs & bumpstops) front and rear.
Interior removed. Central locking, alarm & immobiliser fitted. The interior was washed for the 1st time since 1991.
The correct grey GS steering wheel was later fitted. So the Suntop was finally in a condition I could live with.
Even this filthy lump took a long, and much needed bath...
Mmm, clean... Much better.
Ultimately the Suntop was given a swanky grille to wear, and for a long time it stayed this way...
...and then I changed my mind. Throwing caution into the wind I decided to have my swanky lil bumpers (and the origional grille) painted. It took some time to find a bodyshop I was happy with, but it was worth the wait.
The bumpers looked awesome... the only problem was that they made the rest of the car look old and decrepit. So after another trip to the bodyshop to discuss what I wanted to do with the car, we booked it in and I stripped it down.
4 weeks later...
You may be able to make out the layer of "stonechip" beneath the paint on the sills. The rear valence is also protected in the same way, much like modern cars are.
The wings had been re-sealed with fresh seam sealer along the full length of the wings.
The same level of detail was continued onto the door-mirrors.
The boot lid was removed from the car and painted on both sides. The rust you see on the floor is what I am currently removing.
And this is where the restoration is at the moment. Once all traces of rust have been removed from inside the car, the whole thing will be sent away for waxoyl-ing and schutz-ing. The entire car will then fitted with soundproofing, additional security added, and then reassembly can finally begin.
All rust patches taken back to bare metal with a polycarbide disk, revealing two holes directly over the axle link-arm mounts (very common rust zone). These will both be welded for strength reasons. Obviously I don't want the link-arms to punch through the floor if I hit a bump one day a few years down the line. For now the have been treated with a rust conversion solution, and 24hrs later coated in zinc rich primer.
The rear end was taken back to bare metal too, and treated in the same way.
This area has now been sprayed with the basecoat of red and the first coat of fresh seam-sealer has been applied to all seams/panel joints. (Not photographed yet though)
When the final layer of seam-sealer has been applied and has fully dried, the top coats of red and the clear laquer will be applied :)
Onto other minor jobs: The mirror mount points on the doors were badly corroded, so again they were treated and painted.
The soundproofing arrived today, so once the welding and painting is done I can move on to soundproofing. Something new and quite fiddly but well worth it.
Welding done at last!!! (trumpets)
Interior floor: Left side axle link arm mount location.
Interior floor: Right side axle link arm mount location.
Left side wheel tub, directly over the fuel filler neck.
After some prep-work and zinc priming i layed on the first coat of red. Then pretty much began taking prictures right after, hence why the paint looks wet.
Here's an overall view, painted. No clear coat (laquer) and no seamsealer yet. I wanna let this set up and harden otherwise the seamsealer will pull the paint right off. So this is it untill the weekend, then the whole rear end will be finished. Leaving only the front inside doorsteps to do.
It's a big relief to clear that hurdle because now i no longer require outside help to finish the car.
It is rather tragic that all of this extra effort will eventually be covered up, hidden by the interior.
Rear end now finished woohoo!!!
That seamsealer got well and truely used ;)
Super glossy clear coat laquer, 3/4 of a litre thick. No expence spared here :D
This weekend: Driver's side inside door step, then begin laying on the soundproofing. Spank the bank!!!
First Stage of Soundproofing Done
The soundproofing is on at last. The rear wings and the doors were basically completely covered (leaving space for Waxoyl to cover important areas). Other areas like the boot lid, rear panel and wheel-arches were covered where necessary, and without obstructing anything.
The rest of this job can only be done after the Waxoyl has been applied (this will be done by a pro bodyshop), because the access holes will all be covered when I’m done (essentially doing the job of the plastic membrane).
Last "Rust-Repair" Jobs
These two areas are all that's left to seam-sealer and paint. I'm using Hammerite Smooth Black as the base coat here because it seems to bite in nicely and the red bites into the Hemmerite quite happily. Plus it's good rugged stuff.
The passenger side had some slight rust coming up through the original seam-sealer, so that has been treated with Jenolite and will be getting painted this Friday.
All in all I’m really happy with what I've managed to get done today, thanks to a much needed day off courtesy of the snow. ;)
Well apparently I haven’t updated this thing in just over a month lol.
I don’t have any more pictures to add at this point but in a week or so I should. At the moment the ragtop (as I call it) has been waxoyled and shutzed on the outside. My chassis legs are practically filled with the stuff and every nook & cranny has been covered. This weekend it’ll be going back for more waxoyling on the inside of the car, the front scuttle box-section and the underside of the bonnet.
The next step after that is the window tinting, which is (fortunately) the LAST job to be done by an outside vendor. The front end is assembled, wired up and working except for the badge, which I intend to replace with a new unit. Yay! lol
The Ragtop is going to get re-sprayed again I've decided. I know you can't tell from the pictures but the finish is unacceptable. Rub-through, pits, corners cut that I'm not happy about. The body's shop were given 2nd and 3rd chances to put things right but failed. The problem stems from lack of paint, it's far too thin. I'm going to have to go searching for a body shop that can deliver what they agree to, which will take a while. But at the moment the Super S needs my attention so the Ragtop will have to wait a few months while I tend to that. It's so hard to find true professionals, not JUST in body shop terms but in all industries it seems. So disappointed it. But if the paint is not right then everything else will be pointless.
Figaro front seats and existing k10 split-folding rear seats will be recovered in grey leather to match the Ragtop's interior.
Center console will also be recovered in grey leather - subject to a test fitting first.
Cannot wait to start this summer!
I have been looking into a Figaro swap and its possible just no one have bothered really.
I still want that march grille so bad ;)
