1.0 Micra Mods for Racing
Evening All
Like GlenJ i race autograss but in a different class. My class allows most modifications with a few restrictions
CC limit is 1130cc
Engine is to be from the manufacturer and must have been fitted in that model
i have a K11 1.0 micra (older model with detachable grill)
having read several posts on here and via the WWW it has become apparent that the best starting point is 1.3 cams a good service and jobs a good one.
any other recommendations?
is the 1.3 gearbox any good or better than the 1ltr box?
are the heads the same does the 1.3 have large inlets and exhausts?
any advice appreciated?
Steve
Gearbox and injectors are same on both engines....however the 998ccc runs flat top pistons and the 1300 runs dished so compression is diffrent
Also the 1.3 has a bigger clutch but you don't need to worry about that unless you get over about 90bhp where the 1l clutch starts to give in
gear ratios:
CG10 cg13
final drive: 4.0500 3.8947
1: 3.4118 3.3333
2: 1.9583 1.9545
3: 1.3226 1.2857
4: 1.0278 0.9268
5: 0.8500 0.7556
r: 3.3846 3.4167
