F Fuzzo Jun 28, 2009 #1 hi, can you let me know what the factory compression should be in the K11 1.0L engine. Thanks in advance
frank Club Member Jun 28, 2009 #2 Fuzzo said: hi, can you let me know what the factory compression should be in the K11 1.0L engine. Thanks in advance Click to expand... i would guess 180psi+ on a healthy 1.0 (with stock 196deg duration cams)
baguete Site Supporter Jun 28, 2009 #4 frank said: i would guess 180psi+ on a healthy 1.0 (with stock 196deg duration cams) Click to expand... How about a 1.0 with 1.3 cams?
frank Club Member Jun 28, 2009 #5 bagas said: How about a 1.0 with 1.3 cams? Click to expand... probably 10 - 20 psi less, 222 duration on the 1.3 cams, inlet closes 42deg abdc (1/4 up the stroke) as opposed to 16deg abdc with the 1.0 cams
baguete Site Supporter Jun 28, 2009 #6 frank said: probably 10 - 20 psi less, 222 duration on the 1.3 cams, inlet closes 42deg abdc (1/4 up the stroke) as opposed to 16deg abdc with the 1.0 cams Click to expand... Ok, thanks, will check the compression on my 1.0 with 1.3 cams.
frank Club Member Jun 28, 2009 #7 bagas said: Ok, thanks, will check the compression on my 1.0 with 1.3 cams. Click to expand... np, you might want to check the timings too, i had to advance my misses,s (1.3 cams in a 1.0) a fair bit http://www.micra.org.uk/attachment.php?attachmentid=13127&stc=1&d=1246225039 Attachments PICT0106.JPG 56.3 KB · Views: 1,318
baguete Site Supporter Jun 28, 2009 #8 When i installed the 1.3 cams, i used all the stuff from 1.0, and the timing is the same as 1.0 i think. Wasnt suppose to be like this? My car runs perfectly...
Belly93 to turbo or new lump :/ hmmm Jul 10, 2012 #9 frank said: i would guess 180psi+ on a healthy 1.0 (with stock 196deg duration cams) Click to expand... i got this on mine today frank test1 test 2 Cyl 1 185 173 Cyl2 125 160 Cyl3 169 170 Cyl4 170 173
Belly93 to turbo or new lump :/ hmmm Jul 10, 2012 #11 i was just thinking with cyl 2 being lower than the other 3? or is that not a problem?
