hoodedreeper
Hello,
I've searched and found most of my answers just need clarification.
The car is a 2002 coilpack 1.0L
I'd like to fit a 1.3 prefacelift dizzy engine.
I understand the 1.0L gearbox, clutch, flywheel and driveshafts are to be used
If I was to swap the heads over, would everything be compatible and the 1.0L ECU should fire it up no problems?
Are the ancillaries interchangeable? Starter motor, alternator, PAS pump ETC
Many Thanks
Many Thanks
