1.0 coilpack to 1.3 dizzy engine swap
I have a 1.0 facelift coilpack engine but need a bit more power.
Is it possible to put the 1.0 coilpack head onto the 1.3 bottom with a 1.3 gearbox and driveshafts to avoid much hassle?
I know it’s been asked thousands of times but I keep seeing different answers to this situation, so just want to make sure
No while you can just bolt on the head it wont work. You need more than only the head to use the coilpack ecu. You also need the coilpack flywheel and coilpack gearbox due to the crank sensor thats in it.
