Im wanting to put a 1.3 prefacelift engine block with the 1.0 coilpack head and flywheel. Are there any problems with doing this? Would i have to get a new head gasket?and head bolts? Anything i should do with the engine out?
Nice. I suppose i should pressure test the 1.3 before to make sure rings are good,yeah? Is the flywheel dificult to remove? Any thing i can improve while im taking engine apart?
all my 1.3,s had good compression, but some drank oil and suffered crankpin wear too
you need to drill and dowel the crank too btw (6 bolts and a dowel at 12 o,clock)
