K14 - one wiper not working
Hi, when turning on my windscreen wipers the one nearest the driver doesn't operate. The other one seems to be working OK. Anyone had this before? And how would you suggest fixing it?
Well they only have one motor that works both wipers, the easiest thing to try would be to make sure the wiper arms tight, I think it’s a 14mm nut at the base of the arm and if that’s ok it sounds like it may need a new wiper linkage
