PollyMobiles Rebuild
2023-09-02 Welding Peugeots sills
I was about to try replace the old daily Peugeots rear suspension bush but after hearing the sills crumble on the axle stands, I soon found the sills are rotten & needs welding first :rolleyes:
Chopped & welded the left sill
and the drivers side too
now I can remove the plastic undertray for better access (old fasteners obviously snapped off)
These are the bushes I'm gonna replace soon. The chassis is pretty crusty underneath so that'll need repainting too
2023-09-09 Print Adjustable Bends for Planning Exhaust Manifold
In order to better visualise & plan my equal length manifold, I designed some simple 22.5deg bends
(same radius as the U-bends I prev brought) which can each be swivelled and the groove markings show the relative angles
Took over 18hrs to print all 32 sections, enough to cover the 4-branches
Interesting to play with and make various shapes 😁
made these inserts to anchor into the manifold plate
And it's worked. I'm able to adjust each bend to get all 4 equal lengths to join up and then use the info to make the real manifold
2023-09-10 Velour Roof Lining
On a quiet warm weekend I'm finally able to finish covering up the bare metal roof.
I only have a limited amount of this velour cloth which a car m8 donated to me, so I measured & planned the cuts
Doing this sort of upholstery with spray adhesive for first time, it took lots of planning and was very tricky & messy to do 🙈
That's the top & front covered
Finished the sides & rear
It now looks soo much better & plush inside compared to the bare old finish :cool:
2023-09-30
Trying to locate an annoying rattle around the drivers A-pillar, I noticed the drivers door frame always sat further inwards than the passenger (maybe it's been bent before) so I tried slamming the door with few rags at the top to bend the frame back out to sit better & stop rubbing
2023-10-01 Replace Electric Window Mechanism
Another rattle source are the old drivers power window mechanism, which I used every day and is worn loose & cracked.
Jack gave me a spare set of manual window mechs, which looks kinda similar and hopefully I can swap the motor over with little mod
grinded the manual handle spindle off
curious how the only thing holding the handle & glass position steady is the friction of this coil spring within the casing
drilled out the rivets holding the electric motor
new holes needed to be accurately drilled onto the manual mech bracket to fit the motor
one of the bolt heads also needed machining slim to clear the geared swing arm
bolted together & working. slightly slower cos there's a little misalignment & friction but moves
doesn't rattle anymore
2023-10-05 TIG Torch SuperFlex Hose
A feature I hate about my R-tech TIG welder, which hinders my comfort & learning, is just how rigid & stiff the rubber hose is on the small WP9 torch. This makes it difficult to hold it steady while trying to twist against the heavy hose.
So I need a more flexible lighter hose & heard of ppl using a red Superflex hose.
My WP9 uses a 3/8 hose fitting.
A proper CK9 Superflex torch & hose in R-tech website costs well over £200 and didn't say it fits my machine, so I blindly brought just the £55 hose hoping the fittings match.
Unfortunately it had completely different fittings so I returned it :rolleyes:
alternative option was to buy this 3/8 superflex TIG hose with included connector/gas line on ebay for £40 from china
but turns out the connector was way too small 😤
plus the connector is crimped solid to the hose whereas the R-tech hose is screwed to an adapter 🤨
Definately not gonna send this wayy back to china 🙄
since the gas port is correct, I just need to somehow electrically attach the bigger R-tech adapter onto this smaller chinese connector
so I simply machined & threaded both parts to screw together
and now I have a working WP9 torch with a much lighter flexible hose and it is sooo much better & comfy to weld with.
still need a ton of practice TIG welding though 😅
2023-10-07 Replace Peugeot Rear Suspension Bushing
For many yrs the rear bushing on the old daily Peugeot was perished and needs replacing, plus the chassis underneath is all rusty & needs repainting.
After gathering tools/parts & dry weather, I began removing the rear axle which was a real PITA
the brake hose nut was seized on and uses an odd 10.5mm hex, so not worth attempting that imo, so I'm just gonna let the axle hang down
rubber bush no longer attached
cutting it out with a reciprocating saw was easy enough
thought the new bush I got off ebay was correct but disaster, the original bush is 69mm dia whereas the new bush is 72mm! 😰
failure to fix this ain't an option cos the car is currently sitting on axle stands blocking the back alley.
was slightly stressed & frustrated with this french car cos rain is forcasted to come soon.
but thankfully I was able to machine it down to 69mm on my mini lathe 👍
slips on like a glove 😎
reassembled fast as I could before the rain is due. test drove as all seems good, tight & straight.
gonna deal with the rusty chassis another day 😒
2023-10-09 Lower Bonnet Latch Bracket
The bonnet latch was sitting too high & forward, even at the lowest available position
So decided to chop this section out to refabricate a new bracket
new bracket welded on
now I can sit the mechanism lower & further back on the bonnet latch
2023-10-11 New Horn
The old original horn was getting all rusty and sounded like an asthmatic goat lol
so ordered a cheap dual horn off ebay
old micra horn vs bigger new horn
added a grounding lead
not as deep note as original but does the job
Personal Update:
So since July I've joined a fitness program & Gym with the aim to improve my health, my body fitness, my mindset, my confidence & self esteem, escape this **** delivery job & restart my design/engineering career.
And that's exactly whats happened, I changed into a healthy diet, worked out 4x a week, got fitter, burning my fat away to reveal a beefy muscley body :cool:
This of course boosted my confidence.
Throughout October I overcame many obsticles, each accomplishment boosting confidence including:
- requesting a 1 week holiday off at end of the month,
- resolving my complicated british gas accounts,
- cancelling my broadband & seriously complaining to evil Vodafone bout their dirty renewal tactics, 😤
- through some miracle I managed to connect with a brilliant new gf via my fitness program 😇 this boosted confidence 10x,
- eventually I managed to gather enough balls to request my 2wk notice to leave my job 😎
I timed it so it'd be 1 final week of work,
then 1 holiday wk for a long overdue roadtrip (where I plan to meet my gf along the way) 😎
2023-10-29 Roadtrip To Bolton & Car Crash!
My roadtrip started off with a wet morning
plan was to head towards Bolton (where I first studied car design at Uni and haven't been for 20yrs) to meet up with my new gf.
the weather soon turned nice 😎
next morning I cleaned the car to resume entering Bolton
but DISASTER!
soon as I entered bolton following behind this blue Tucson, I saw a lorry was about to join from the left, so I indicated to switch to right lane, the Tucson suddenly went to the middle of the road & emergency stopped for no reason and no traffic ahead 😨
it was too late, I was startled, slammed & locked the brakes on this damp morning, slowly smashed into the back of him with a bang!
ah fck my poor baby, WTF the eejit stopped for!?
checked the guy & passenger are alright, he said sorry his tucson tends to jump outa gear for no reason (🤔 later discovered it was an automatic?) and he said don't worry he won't claim cos theres very little damage to his plastic bumper and was gonna leave, whereas my poor front corner was caved...
woah woah fella, I was stressed & confused of the correct procedure during my first crash involving another car but I at least remember to photograph the scene, I had GoPro footage of the thing, I noted the guys details & mobile number, calling him to verify it's authentic too incase its a scam.
still shaken up, I pulled over to the side to call & inform insurance with the details. since I have £300 excess, I could either fix it myself under £300 without claiming or increasing premium,
or claim if it's over £300 to repair but affects premium etc
well she still drives fine, just cosmetic and there's 4hrs of daylight left, I decided to nurse her home to mend.
soon after, this asian recovery dude came past offering to recover her to a local shop to mend with courtesy car etc for a good price, erm thx but nope. I'm set to fix it myself at home.
at this point I'm aware of the old Crash-for-cash scheme and was completely paranoid of everyone trying to scam me 😨
my anxiety in survival mode just wanted to get home ASAP
I thought this was game over for kassandra & my chances of meeting up with my gf, I felt devastated 😭
along the way home I decided to stop by Jack near home for some spares & mend her
with his help, it wasn't too bad, just needed some gentle taps to straighten things up 😅
that'll do for now
back at home & finished hammering the panels straight and realigning the headlights
she's back to her original battle-scared wonky look but good enough to resume my roadtrip (y)
2023-11-01 Roadtrip Part 2
After repairing the crash damage I resume the roadtrip, heading straight back into Bolton haha 😅
this time I went via another way & was fine
the plan was to meet up with my gf when she gets the train from down south,
unfortunately there was a big storm warning down south potentially disrupting trains and she was really stressed bout travelling by herself for 1st time.
so instead I decided to drive 6hrs through the early morning down to london to pick her up & bring her along her 1st roadtrip 😎
we had a nice 1st date. I went to get kassandra a much needed handwash at tesco 😁
we drove up to Kendal at the Lakes
found this nice underground parking, of course I had to take a photo :cool:
drove 7hrs to drop her off back home but due to expensive hotels down south I had to drive a further 3hrs through foggy b-roads to a hotel in cambridge, exhausted 😴
next morning was a nice sunny drive home 😎
2023-11-21 Test Fit Front Panels
Visited Jack for a catch up and collect some spare parts to mend Kassandra including spare bonnet, front wings, door hinges & switches
removing the front end to assess the damage
the outer panels & bumper bracket took most of the brunt
the chassis legs remain ok
swapping the spare panels & bumper over
at first it seems the wings & bumper don't match up
the LH crash has definately crushed the left bumper bracket further back by 1cm
the bonnet also touches the wing probably due to the LH impact bending the raised bonnet hinges to the right
the biggest issue is that these newer preface wings appear to be slightly longer than the 1993 chassis, the front bolt holes don't line up :unsure:
I'd have to replace & realign the whole front chassis panel to make them fit
I also swapped over to another spare genuine but damaged wings I got from Max Plester yrs ago and they fit my 1993 chassis much better
https://micra.org.uk/threads/pollymobiles-rebuild.35251/page-184#post-782101
the front curvature of the genuine wing aligns better with the spare genuine bumper. my current painted bumper seems to be a squarer copy part, which is why it never lined up with the grill/headlight/wing
the genuine wings are shorter and the holes line up to my chassis.
I'll be using these genuine wings in the coming summer but will need a ton of body repair to straighten all the dents out 🙈
note how the shorter genuine wings have Nissan stamped on whereas the later, longer pattern parts are blank
2023-11-23 Replace Door Hinges
For the past few months I've had this really annoying buzzing sound from the door/A-pillar while cruising, which was really difficult to locate and stops when I press the top of the door.
Jack said it'll be worn door hinges allowing movement and yeah my 30yr old worn drivers door also has upto 2-3mm of vertical play 🙈
So replaced them with newer hinges
and now it no longer rattles/buzz during cruise. much quieter 😎
replaced the hazard switch which had a blown bulb
the top left turret top has some rust
cutting a small piece out to check underneath wasn't too bad
replaced the worn RH ball joint before her MOT
the cheap wipers I got from work doesn't last any longer than few months before it smears, so grabbed some better ones at halfords for a tenner, wipes better now
2023-12-11 Welding Mercedes 190E Wheel Arch
In preparation for continuing to repair my m8s old rusty Mercedes, I made some simple free butt-welding clamps rather than paying over £20 in machine-mart
They clamp the thin panels closely like this
So visiting his garage, I marked the area I'll cut out to replace with a spare panel
Bit of the inner arch is also rotten
Due to the thick factory seam sealer, I ended up chopping both the rotten inner & outer skin off together
You can see the old sealant bonding the two together, making removal difficult, plus a fire hazard when welding back together
Roughly trimmed a new section to test fit
Carefully trimmed the ends till the curve lines up
Shaved the rest of the panel edges till it very precisely matches the cut hole within 1mm and used my new clamps to hold the edges aligned
Tacked on
& slowly stitch welded it together. grind it flush later on
Cut some pieces to rebuild the inner arch
Rebuilding the front part.
Welding within a tight wheel arch will always be very awquid, hot & difficult with a few burns 🥵
& the rear part
Changed oil & filter
Here's a look inside a micra horn
12v would energize the voice coil,
pulling the middle plunger down, which breaks the contact switch,
coil relaxs, plunger springs back up, contacts touch & repeat.
The curved dish attached to the oscillating plunger creates the horn sound
The tiny screw on the side adjusts the contact resting point, which affects freq and thus horn pitch
Kassandra passed her MOT but barely 🙈
handbrake was too weak (I'll overhaul the calipers & replace the rear disc/pads),
my modded tie-rods might be an issue (so may need to revert back to standard hub/arm/rods),
fast idle emission is barely ok but really struggles on low idle (primary cat is probably worn out by now).
lot's on my to-do list :rolleyes:
rear pads are now half worn and discs have a noticable rusty lip but feeling little weak so it's best to replace em
fitted some new discs (BrakeWorld RS3657) & spare pads that Jack gave me. the thickest set of pads (DriveMaster PAD780) were 18.15mm (way too thick to fit within the calipers) but it was easy enough to sand em down to 17.5mm to fit inside the fully retracted piston
Quote: “discs have a noticable rusty lip but feeling little weak curious?
Pictures of said discs with lip & brand, age & useage is of considerable interest please?
Brake pads were Blueprint ADN14283
Brake discs were Bosch 0986479104
Fitted back in January 2020
https://micra.org.uk/threads/pollymobiles-rebuild.35251/post-781787
Currently only half worn, they've covered 36.5k in 4yrs, daily commuting with occasional intense long trackdays.
The inner pads always wear out faster than the outer :unsure:
During this yrs MOT her hydraulic braking force is fine but the handbrake force is barely ok & weak (either the mechanism needs adjusting, handle still clicks upto 7, or the pads are old & glazed, therefore replace em)
They look like this now
The outer side looks meh ok
But the inner side you can see the lip where it's been constantly rubbing away over the yrs
Many thanks & good info food for reflection.
My 26 year old K11 on 65K has original Nissan front discs, exhaust, ancillaries, clutch, & eng/gbox & has never reqd any MOT/welding!
It just keeps going & passing straight thru successive MOTs with no advisories, only my simple basic DIY maintenance & I keep it away from any garages & mechanics.
Sometimes steady is quick & less is more?
Happy days. :)
It's been a terrible last few months for me.
Quit my last job as delivery driver since Nov (in the hope I'd have the confidence to find a new proper job in the new year).
In december I split from a lady I was seeing since Oct, who used me and broke my confidence.
In new year I very briefly met another lady during dinner with m8s, we got talking but it didn't work out, and this finally broke me.
I didn't trust anyone and deleted almost all my friends.
I don't even trust myself rn, just sleeping lots, zero motivation to do anything, avoiding ppl, gave up exercising, gave up my diet, eat sleep tv + game, drain my savings :(
I'm falling back into my 2015 depression anxiety days 😭
So Jack was aware of my situation and asked me to give him a cruise out since he was gonna go buy another micra (it gets me out the house and he paid the fuel/food which was cheaper for him than taking the train)
while Jack was buying the car, I noticed my air filter duct was broken, oops another thing to mend once I return home 😅
2024-01-23 Print Stronger Air Intake Ducting
After the drive with Jack down south to collect his new car, I discover the printed air duct was now deformed (maybe from heat & vibration & not being rigid enough)
I redesigned a stiffer mounting
took over 15hrs to print 😬
while it was much more sturdy bolted to the chassis first, it meant that taping the air filter onto the ducting afterwards is a PITA being soo close to the wheel well/turret
but once it's all assembled, it's rigid & clean looking
Checking the brake wear today.
Discs look good
Front pads fitted 7mths ago are nicely bedded
but the fresh rear pads I fitted last month ain't fully bedded in.
bare in mind I had to manually sand it thinner cos it was originally too thick, so it wasn't perfectly flat hence why the edges ain't worn down yet and braking force ain't 100% yet
front pads wearing at a normal rate
thicker fresh rear pads barely bedded in, they need at least 2k miles or 3mths
spent the day cleaning & buffing the brake dust off the wheels after a harsh winter 🙈
2024-02-17 Replace Handbrake Cable
The old handbrake cables are now getting old, hard, sticky, not fully releasing therefore making the rear brakes drag slightly
Jack sold me a pair of spare LH cables for disc brakes
Comparing the old cables with the 2x LH cables, I'll need to mod one of them to fit.
The support brackets are easy enought to swap
The locating peg stills slots onto the chassis hole but the fastening hole is on the opposite side, so I simply bent a P-clip bracket to secure the cable in place
Fitted the rest of the brackets
The handbrake now works really smoothly and relaxs fully so the brakes no longer drag slightly :cool:
I can see on your last picture that we have the same "Makifake" impact wrench Paul! Bought it with a battery and the charger for 30 euros shipped a few years ago, one of my best purchase!
yup for the odd light wrenching on/off they're fantastic value & really handy/speedy
Yes exactly, I've been looking for a long time at some cheap ones sold at Lidl, but they are always sold without battery nor charger so in the end all combined they turn to be too expensive, and I'm not really fond of tools on battery, but this tool is so compact, lightweight and no hose, much more practical than a pneumatic one. Also pretty handy for track days.
I agree.
Yeah it makes wheel swap on trackdays soo much better whizzing em on off.
Used to take forever to hand screw all the wheel nuts in the early days 😅
Engine bay is abit filthy & needs cleaning for Japfest coming soon,
I printed these little covers for the spark plug holes
then jet wash all the dirt & oil stains off
wipe dry & reassembled
added the labels onto the new catchcan lids
the rear caliper dust boot was recently damaged so I brought this caliper seal kit
she finally reached 220k recently 🥳
Years of gathering materials in my messy workshop needed a good sorting/organising/stock check and it's such a rabbit hole to dig into 🙈
The preface speedo pinion is leaking a tiny bit of oil past the shaft, plus curious what's inside compared to the electronic pickup
easy enough to punch out the roll-pin and take apart. can see the shaft/seal area is quite worn
the seal is deep inside the casing and hard to remove so I'll leave it alone, ain't a big issue
2024-03-01 Pipe Chamfering Tool
For chamfering the pipes when welding up my exhaust manifold, I designed this jig for the bench grinder
printed the tool
it holds the pipe at the correct angle/distance while I spin the pipe across the grinding wheel
giving a smooth consistant bevel
2024-03-01 Lathe Cutting Tool Sharpener
Modelled the cutting tool angles I'm aiming for
Designed this jig for the bench grinder.
First I sharpen the side cutting edge, held at 10deg
Followed by the front cutting edge, held 90deg to the side cutting edge
The final step is grinding the top to add Rake angle on the front cutting edge
Printed the jig
Spent hours slowly grinding the tip
Cuts really nicely :cool:
2024-03-09 Measure Fuel Level vs Fuel Gauge
During the process of swapping from a preface fuel tank to a facelift tank, I was curious to compare the fuel gauge accuracy to the actual fuel level.
I ran the car till the gauge was empty and drained the tank
Removed the walbro pump out the tank before the water test
The current fuel sensor (top: from preface 1998 SLX) has a separate fuel warning light moisture sensor,
whereas the spare facelift sensor (below) doesn't
I measured the resistance range of the sensor throughout the 55deg range of the floating arm, note the reduced ohm sensitivity near the min/max to compensate for how the arm would swing more as it gets near the top/bottom of it's circular stroke relative to the vertical fuel level
Refitting the tank briefly, I fill it with water while monitoring the gauge, noting how many litres it took to reach each marker
Here's the resistance of the float sensor relative to the amount of fuel remaining
And this is the amount of fuel in the tank relative to the fuel gauge needle
Notice how it over-estimates the top end and under-estimate the low end.
Since the graph shape of the sensor resistance matches the gauge reading, it seems the pear shaped fuel tank could be causing this odd behaviour.
The bottom of the tank is smaller compared to the mid-section due to the exhaust pipe clearance, which explains why the last 1/4 tank always run out fast.
And the top half is smaller than the mid-section due to all the odd indentation, breather pipes, access hole and sloped shape of the back seats taking up space, explaining why the top 3/4 seem to drop fast soon as you drive a few miles after a full tank
2024-03-09 Swap Pre-face Fuel Tank with Face-lift Fuel Tank
Since 2012 I've been running a Walbro 255lph pump in a pre-face fuel tank.
https://micra.org.uk/threads/pollymobiles-rebuild.35251/page-36#post-482610
The prefacelift pump motor/housing are larger than the Walbro pump, which was meant to fit smaller facelift tank housings, so for years I had to simply wrap the pump with rubber sleeve to fit the large opening and I'm concerned about durability of foam rubber.
I brought a spare facelift fuel tank to fix this
(left: preface tank, right: facelift tank)
So here's the old walbro pump wrapped in rubber and wedged into a preface mount (left)
vs the smaller enclosed facelift pump (right)
Comparing the larger, open-top early pre-face fuel pump surge-tank (left) to the smaller, enclosed face-lift surge-tank (right)
The preface surge-tank was very difficult to remove and had to break it out.
From the bottom view, note the fuel return pipe which features a narrow jet nozzle aimed at a small opening into the surge-tank, which uses the venturi-effect of the return flow to help force fresh surrounding fuel in the large tank into the surge-tank.
The surge-tank keeps the pump pickup submerged for few secs during any sudden sloshing (especially during low fuel) to reduce fuel starvation.
The preface has a larger surge-tank but the open-top design could let fuel slosh out the sides.
Whereas the facelift tank is smaller/shorter but fully enclosed, so more of the fuel inside will stay with the pump for longer during hard long accelerations
The surge tank bottom mounts are kinda similar (preface: left, facelift: right)
But the reason the preface surge tank was difficult to remove was due to this 1-way inaccessible latch (top)
while the facelift surge-tank has a rounded latch allowing the whole thing to easily removeable (bottom)
Comparing my current walbro pump to a facelift pump, I noticed a big issue.
The fuel pickup strainer that walbro supplied me in 2012 was actually upside down and wayy too long for the facelift tank :cautious:
walbro is also 2mm longer than a facelift pump.
Only reason it worked on my preface tank is cos it had a longer surge tank & I could mount the motor upside down
To fix this, I removed both strainers
And fitted the facelift pickup onto the walbro pump.
It's a little squeeze fit with the longer motor
Surge tank complete
Next issue is swapping over the heat shield, where the facelift plastic mount was broken off
I simply tigersealed the thing on lol 😅
All assembled and now has a strong buzzing sound during startup.
Ecu map may need a slight tweak cos there's an odd leanout during light throttle
(have to check if it's a mapping isse, wideband issue or fueling issue)
edit: I took out the sensor to just inspect and looked clean and now it doesn't randomly lean out. maybe just unscrew/screwing the thread made a better contact, does a wideband sensor ground via the manifold like a regular narrowband or does it have it's own ground within the 5pin plugs? :unsure:
2024-03-15 Inspecting Fuel Tank Components
While feeling sad I decided to dismantle some old parts to see how they work.
Pre-face fuel pump vs face-lift pump:
so here's a preface pump which is larger and has a slightly different inlet port
the facelift pump is slimmer
the pump itself are the same on both using an axial flow impeller
the major difference are the preface motor has a larger diameter Armature and the contact brushes slide in from the side like all normal motors
the facelift motor has a smaller cylindrical Armature and the contact brushes slide in from the rear instead, never seen that before
brush still has plenty of life left
Fuel tank Breather system:
always been curious whats inside this small tank on top, I thought it was some baffle system to stop fuel sloshing back out the breather
erm nope it's simply an empty hollow chamber lol
inside the check valve is a combination of a regular diaphram valve at the top and an inertia ball valve at the bottom
the orange diaphram on top allows air from the carbon canister to flow into the fuel tank as fuel level drops and some fuel vapour to slowly seep out to the canister while parked but prevents any dense liquid fuel or slightly pressurised gas flowing out to the canister.
the heavy steel ball valve closes a pinhole/breather whenever the car is under any g-force or tilted/upside down (only opens when sitting upright and stationary or cruising steady)
Fuel Cap:
inside a regular fuel cap is a ratchet slipping cap (limits how tight it's screwed onto the filler pipe so it's easier to remove next time),
rubber o-ring seals the cap to the filler pipe,
but inside is a 2-way valve similar to the radiator cap.
if there's ever too much vacuum pressure in the tank (ie fuel level drops while driven but evap check valve stuck closed) the large Green valve allows air in.
but if there's too much +ve pressure in the tank (ie fuel vapour builds up pressure on a hot day but evap valve is closed cos car is parked on a incline) the small Red valve allows gas to escape
2024-03-14 Insurance Drama, Mental Illness
I rang Adrian Flux for a renewal quote and was jaw dropped when quoted over £750 fully comp, £600 TPFT !
what the hell? that's almost doubled of the £410 I've been paying for last few yrs :eek:
Called afew more insurers and not many will insure her or still quoted the same £600-700, but that's where I found there's still an incident logged on my system under 'my fault'.
WTH I simply reported a small crash, didn't claim, was informed by AXA they'll send a letter to other driver plus Adrian Flux to verify it's been settled and then close the case, and yet it's still left open and I'm punished with a doubled Premium?
What's the point of paying for insurance or even reporting anything without claiming if insurance is simply gonna fine us for being an honest person? 🤬
I'm already going through a big depression/anxiety this yr after breaking up with my ex, quiting my job and giving up hope (same cycle as in 2015)
but now after the stressful call (I hate phone calls) I'm even more worried I may not be able to afford running kassandra for next 5yrs, may have to give up the car, the upcoming shows, my hobbies, my life 😭
After a sleepless night full of -ve little suicidal thoughts, the next morning I had to gather yet more energy to call AXA about why that incident case is still open, which is mainly why all my quotes are through the roof!
It turns out that AXA (insurer) sent a letter about the incident to Adrian Flux (broker) & the other driver awaiting confirmation it's been settled before they close the case BUT they actually didn't receive any reply therefore left the case open under my name At Fault 🙄
Since it's been 6mths later, the guy said he can now close the case, email me the confirmation to show my insurer it's been resolved and hopefully that'll lower my premium.
My mind is scrambled egg 🤕
I'm questioning whether I really need to goto GP to get diagnosed for depression, anxiety, autism, ADHD, APD cos I'm still scared of finding a new job, scared of making the wrong choices 'again' cos I feel something is definately wrong with my brain
