T The Fairy Godmother Oct 5, 2016 #1 As above, I am currently converting a Pao from 1.0 to 1.2, most of the work is now done but need a carb. Sent from my iPhone using Tapatalk
Fujiwara-Ben Site Supporter Oct 14, 2016 #2 You can use the 1L carb. In fact it's actually better to use the 1L carb as it has bigger jetting than the 1.2 carb so you'll get a bit more power Also the 1L is known as an MA10 and the 1.2 is an MA12 Hope this helps
OP OP T The Fairy Godmother Oct 14, 2016 #3 Fujiwara-Ben said: You can use the 1L carb. In fact it's actually better to use the 1L carb as it has bigger jetting than the 1.2 carb so you'll get a bit more power Also the 1L is known as an MA10 and the 1.2 is an MA12 Hope this helps Click to expand... Ben Thanks for this, while I have got it running, I think that I will try the MA10 carb as you suggest. Sent from my iPhone using Tapatalk
Connork10 Apr 27, 2017 #4 I have a 1leter carb here that i have for spares for my car pm me if you want it?
