Greetings from Finland!
First of all i apologize my bad english, but i will try my best.
I bought k11 -93 in january 2015. (this is my 4. micra so not so new thing to me.)
In summer -15 i start modding my engine to run with alcohol (re85 is what we get from pumps). This was easy, just megasquirt 1 with 2.2 board, few mods to trigger and i got ms'n's. Then the problems came. First my injectors was dropping once on time, i changed injectors to newer (i think -97 micra 1.0) and solved problem with injectors. Then was turn for fuel pump, no more pressure production from std fuel pump. So i bought aeroflow e85 pump. In these time i realize that i got very expensive micra for just e85 conversion, so i opened ebay, few clicks and itb's from gsxr600k8 was arriving to finland.
I bought also some 750 yamaha's exhaust manifold.
After some laser cutting and alloywelding and fitting i got parts to my engine bay. I bought plx wideband lambda also for see my real afr.
Then i got bored to low performance and bought 1.0 pistons, head porting&polishing and 280 degrees 9.6mm lift cams. I get rest of parts back to carage at next week and i start building engine back to hitting roads.
But now i got few questions:
-Do i need stiffer valve springs for mild cams? ( top of nose is like /\ )
-what i should do next for getting better performance? (i have talked with local maching shops for billet flywheels) and i got allready 1.0l crank pulley. I have thinked about NOS, just for fun, but it doesnt make power all the time.
Is it save to raise revlimit to 9500 with just balanced pistons+rods? i am not going to do more yet for bottom, i got few spare bottoms for explode.
Do i need better clutch yet? i dont even know how much i should get hp?
ofc i got front pipe and cat back and decat. d.i.y all of them.
Other mods with micra isnt making more power but they are:
-Custom corsa d and b coilover with uniball topmounts, all new bushes and joints, facelift almera 252x20 front brakes and 14x7 alloys with brand new michelin 185/55r14 and recaro seat for driver.
