Hi,
newbie to this forum so please be gentle ?
Have a micra c+c which has decided to control the hazard lights by itself, spoooky. They come on by themselves when driving and cannot be switched off using the switch. Have accessed the switch itself and disconnected it, no difference, searched the forum and the finger points to the BCM, did think it could be a faulty relay but from what I have read it’s within the BCM.
Having done some research used BCM can be bought fairly cheaply but will need to be re-coded from the original unit or company BBA Reman can repair original units. So to the challenge where is the BCM and how do you remove it ? Read that it’s behind centre console, have removed radio and no joy.
Any advice is most welcome ?
thanks
thanks
