solarice
Right got a few bits that are taking up space, so they are looking for new owners. ![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
K10 Stuff (will be updated as and if i find more stuff) -- all from a 1.0
1. Stock orange side repeaters (lenses only) -- As new : £1 + p&p
2. Carb and inlet manifold (carb has an idle issue, probably just needs rebuilding but never looked at it as i just replaced with a working unit) : £5 + p&p
3. Radiator fan and motor -- was working 100% when removed : £10 + p&p
5. Ash tray in brown -- slight wear : £1.50 + p&p
6. Lockset (NOT including ignition) -- three of the four have very neat faces, one is messed up slightly arround key hole -- I need to find the key for these. : £?? + p&p
7. Factory cigarette lighter -- some wear on element : £1 + p&p
8. Radiator Header/overflow tank and hoses : £10 + p&p
9. Ariel : £3.50 + p&p
10. Factory Air box -- slight surface rust on lid : £?? +p&p
11. Radiator Drain Plug : £1.50 + p&p
12. Fan controller thermostat (bolts into radiator), was working when last used so should be fine : £2 + p&p
13. Random Hoses -- Tell me which bit from the pics you want and we can work out prices. : £?? +p&p
14. Inlet manifold -- Bare : £?? +p&p
Instead of uploading new pics, if you check this old forsale thread you can see the pics there...these are the same items so whats in the pics is what you will receive, so long as its listed above.
http://www.micra.org.uk/threads/numerous-k10-parts-available.6309/
K11 Stuff (will be updated as and if i find more stuff) -- all from a 1.3
1. Early K11 Throttle body (removed from a 93 iirc) -- Tested and working : £35 delivered.
2. Early Type K11 front grill (my original grill) -- in white (has been repainted) and in stock condition : £10 + p&p
3. Early Type K11 front grill -- partially cut up, has a crack thats been glued...needs finishing : £?? + p&p
4. Cam cover -- needs a good clean inside and out. : £?? + p&p
5. Standard fuel pressure regulator. : £?? + p&p
6. Standard Inlet Manifold : £?? + p&p
7. Drivers and Passenger Wing Mirrors (black plastic, both have slight scratches iirc) and base plate trims (non adustable from inside of car) both are folding iirc : £6 each + p&p
8. Pre-facelift Boot number plate light (non handled) -- slight surface marks (so ideal for spraying) no lights or metal screws, but all mounts are intact. : £6 + p&p
9. Two inner CV Boots -- Brand new in box (need to find what i paid for them really) : £?? each + p&p
Open to offers on all items...so send me a pm.![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Any items that dont have pics i can provide them on request.
