you know when you open the door with your lights on it beeps? (talking k11 here)
well i tracked it down to a little yellow box behind the shelf under the steering wheel.
now the beep sound sucks so i went to a scrappy and got a chiming one out of a hiyundi accent *spelling
i thought that it would be a straight swap because all it needs to chime it 12v and i thought that was what the other one did as well but when i got a multimeter on it the negative wire actually pulses. so all the little yellow box did was make a constant beep sound and with the negative pulsing on and off it made a beep beep sound....
i need to find out what makes the negative wire pulse. i'm assuming it will be a relay somewhere but i can't follow it becasue it goes right inside the dash...
and the haynes manual doesn't even show it grr
anyone know where this wire goes or where this relay is?
any info would be loads of help thanks ppl
