Hi All,
Selling the micra as brought an almera GTI.
Car is cheap because it does need some work doing to it...
Basics:
Mods:
Good points:
Bad points:
Pictures can be found here:
http://picasaweb.google.com/rlees85/HostedImages
Please ignore the one of the flying pig!!
Car needs to be gone in 2 weeks due to parking permit and I have nowhere to put it. If no interest in a week its going on eBay.
Cheers all!
Basics:
- Mileage is 75K, odometer reads 138K because I changed the speed clocks.
- 51-Plate
- MOT expires in April, last MOT it passed no problems...
- Tax runs out around july/august/september.. it is included anyway.
Mods:
- OZ racing lightweight wheels, 15", pretty much new uniroyal tyres all around. Still in fairly good condition but not immaculate.
- Almera airbox (although I can fit standard one before sale)
- Full Janspeed exhaust (normal) but the de-cat is stainless steel.
- Light Flywheel
- CGA10 Gearbox (installed about 10k ago with new heavy duty clutch).
- Almera 1.4/1.6 brakes with mintex discs and pads.
Good points:
- Interior is in pretty much immaculate condition
- Drives very well, engine is very responsive
- Dyno proven 100BHP
- Bodywork looks good when cleaned, most of its nice and shiny.
- No rot or rust anywhere, no signs, I am sure it wont even start to rot for a long time yet.
- Low Mileage, 75K
Bad points:
- Passenger side CV Joint will need attention. Might just want a clean and re-grease but might be knackered.
- Heater only works on full and I cannot find the resistor card.
- Passenger door lock is missing and filled in very badly, paint is dull around that area, could need a new door if you wanted it to look mint. Someone tried to nick it a while back.
- Very very minor compression loss on cylinder 3. (The other cylinders are at 14Bar and the third is at 12Bar). Does not affect the driving of the car however does bring on the engine light. This started when a spark plug broken into the combustion chamber and smashed a valve. The valve was replaced but it seems it could use a new head to make it perfect.
- Janspeed backbox is rotten and will need replacing.
Cheers all!
