CMF_Micra_King
» CMF MemberOk guys heres your chance to get some top gear for far less than buying it all new if you can even get it still.
The items are going to be sold in set packages only, eg we will not be selling just the supercharger on it's own.
big items are as follows.
Complete engine and gear box package.
ENGINE : Factory CG13DE
BLOCK : Decked, O-ringed
PISTONS : HPC coated SPS forged pistons 2mm taller crown with friction modified skirts "Perfect Seal" gapless second rings
CONRODS : PAR 4140 forged billet rods, ARP bolts
HEAD : High Flowed
CAMS : Datrats "serious" 24-8A cams 258 deg duration COMPRESSION : 8.0:1 with hybrid gasket
Super charger : Toyota SC12 Supercharger from 4AGZE
BOOST : 12psi from Datrats larger main drive 1.5:1 step up hardened main drive lightweight alloy pulley
INTERCOOLER : Toyota MR2 front mount, Spearco water injection running 50/50 water methanol mix
THROTTLE BODY : Nissan Pintara throttle body mounted pre supercharger.
INJECTORS : Modified SR20 fuel rail with S13 SR20DET 370cc/min injectors.
COOLING : Datrats aluminium racing radiator, Davies Craig electric water pump with EWP smart controller
IGNITION : Bosch twin coil packs.
GEARBOX : Rebuilt Nissan E15T RS5F31A gearbox modified to suit CG13DE engine along with modified E series starter motor
DRIVESHAFTS : Standard micra shafts
FLYWHEEL : Datrats lightweight alloy flywheel (3.4Kg)
POWER: 99.5kw@wheels @ 6500rpm.
CLUTCH: Has a brand new heavy duty clutch fitted which cost $800 alone.
Engine runs great but please note it will need the head gasket replaced.
Price $2500 No offers please as you will need to spend 3 times as much at lest to get this built up.
ECU: Autronic SMC unit. $800 or $500 if you buy it with the engine package.
SUSPENSION Package: Whiteline swaybars, panhard rod, strut brace, kmac 50mm drop springs, koni adjustable shocks. $800
All other items will be up for sale once the main parts are sold. Parts like sport seats with rails, Rims and tyres,
Brakes, interior odds and ends, gauge package,
headlights and tail lights and so on.
The member Justo owns the car but I will be the one stripping it down (Doing all the hard work) Engine/gearbox can be shipped anywhere in aust at buyers expense but should not be to much and will be shipped well strapped down on a pallet and shrink wrapped.
Feel free to pm me direct if you need info on anything or the owner Justo on this forum.
HEAD : High Flowed
