In the beginning…
bought it December 2005…
the interior…
[FONT="]
[/FONT]
the engine (1275cc)…
parked on the drive…
first mod was the alloys…
not much of a match against Ayats car lol…(cheers to Ayat for the wheels also)…
back home washed and parked on the drive…
[FONT="]next the suspension was arriving thick and fast after an agonising wait from whiteline (konis)…[/FONT]
[FONT="]
[/FONT]
Anti-roll bars…
Castor, camber kits…
more goodies, (see spec for all info)…
I fitted the fully refurbished Gtir callipers and disks at the same time as the suspension…
fitted on the car and the suspension also fitted…
in the garage parked up…
view from the rear…
forgot to mention the exhaust lol that was before the suspension but around the same time (month) if ya see what I mean…
Showing the clearance after a couple of days to settle…
once suspension phase one had settled I was off to get it all set up and the remaining bits added…
Next some custom cold air feed in the form of K&N panel filter and extra cold air feed…
Next was the march rear clusters, subtle and I like it that way…
Some MOT repairs to be carried out front cross member…
sills replaced…
new tyres too (toyo T1-S’s)…
tread pattern…
Toyo…
Now some colour coding…(boot handle)
door handles…
more…
interior was progressing throughout so pics in no particular order…
leds instead of the lights better me thinks…
more speed required so a janspeed manifold was added to complete the exhaust system…
clear side repeaters now…(again nice and subtle)
another angle…
and a bit of flash action…
random pics taken on the 8th of march 2006…
now onto the more interesting stuff…hidden beneath the bonnet is a new surprise(see spec list)…
Engine:
CA13DE 1275cc
Turbo: Garret T2
Braided oil feed/return, and water cooled
Intercooler: Calsonic R33
Customised to suit the chosen setup
Manifold: HKS cast manifold
From the Nissan Cube bolt on kit
Exhaust: Custom 2 inch exhaust down pipe, flows from turbo to de-cat
Janspeed De-cat
Powerflow custom cat back system with 3.5inch tailpipe
Engine management: Greddy E-manage
Injector harness
Ignition harness
Pressure sensor
Fuelling: Adjustable fuel regulator
1.6 Primera injectors
Blow off valve: Bailey Twin Piston type, atmospheric dump valve
Actuator: R5 Turbo adjustable actuator
Hosing Samco: – Blue (nice contrast to red paintwork)
Air filter: K&N generic cone filter
Gauges: Rally comp boost gauge
Suspension:
Dampers: Koni Adjustables (internally shortened to suit whiteline setup)
Springs: Whiteline -42mm springs front and rear
Anti-roll bars: Whiteline 22mm heavy duty swaybar front
Whiteline 22mm Adjustable HD rear swaybar
Strutbrace: Whiteline upper and lower control braces
Panhard Rod: Whiteline adjustable panhard rod
Camber: Whiteline adjustable camber bolt kit
Castor: Whiteline castor / traction control arm
Wheels:
Team Dynamics 15 inch “Motorsport” Rim
Tyres:
Front: Toyo T1-S’s 195-45-R15
Rear: Khumo generic 195-45-R15
Breaks:
Front: Fully refurbished Gtir Callipers
Standard Gtir Disks
Rear: Standard factory drums
[FONT="]
[/FONT] Exterior:
Body modifications: Non (subtle kit planned and air vent required)
Lights: clear side repeaters
March import rear clusters
Interior:
Seats: Red/black seat covers (MR2 seats to fit)
Wheel: Momo competition copy wheel
Gear knob: Momo generic
Lighting: Blue LED’s to replace cluster bulbs
ICE:
(Standard at the moment waiting to buy amps and new headunit)
To be fitted…
Front speakers: Alpine component kit (SPS-171A)
Rear speakers: Alpine 6x9’s (SPR 69LP)
To be continued...![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
![28-Mynew%20car%20possibly.jpg](/proxy.php?image=http%3A%2F%2Fwww.moddedmicras.co.uk%2Fupload%2Ffiles%2F28-Mynew%2520car%2520possibly.jpg&hash=91f924dc5caf0e8af0b39cd3ae2d7d40)
the interior…
[FONT="]
![23-MyCarInteria.jpg](/proxy.php?image=http%3A%2F%2Fwww.moddedmicras.co.uk%2Fupload%2Ffiles%2F23-MyCarInteria.jpg&hash=cf947a30d50ce46ea32054586b9f1675)
[/FONT]
![21-MyCarbonnetopen.jpg](/proxy.php?image=http%3A%2F%2Fwww.moddedmicras.co.uk%2Fupload%2Ffiles%2F21-MyCarbonnetopen.jpg&hash=6ad554d0ddd6607fdfae1071fe6b598b)
![27-MyCarFL.jpg](/proxy.php?image=http%3A%2F%2Fwww.moddedmicras.co.uk%2Fupload%2Ffiles%2F27-MyCarFL.jpg&hash=29c71d7d5b1be251e9ed5987a2db34c4)
![2-Image049.jpg](/proxy.php?image=http%3A%2F%2Fwww.moddedmicras.co.uk%2Fupload%2Ffiles%2F2-Image049.jpg&hash=71570dd33b3e7a6a1b6ac7538a322239)
![9-Image047.jpg](/proxy.php?image=http%3A%2F%2Fwww.moddedmicras.co.uk%2Fupload%2Ffiles%2F9-Image047.jpg&hash=78f17481b9081c100856e4ca0b786d41)
![20-carondriveoverhead%28web%29.jpg](/proxy.php?image=http%3A%2F%2Fwww.moddedmicras.co.uk%2Fupload%2Ffiles%2F20-carondriveoverhead%2528web%2529.jpg&hash=ba74772bd4b9319458669b1b3291f817)
[FONT="]
![29-koni-inserts%28web%29.jpg](/proxy.php?image=http%3A%2F%2Fwww.moddedmicras.co.uk%2Fupload%2Ffiles%2F29-koni-inserts%2528web%2529.jpg&hash=142f2dfb8c1b1a2a00161bbfe0a43e16)
[/FONT]
Anti-roll bars…
![6-antiroll-bars%28web%29.jpg](/proxy.php?image=http%3A%2F%2Fwww.moddedmicras.co.uk%2Fupload%2Ffiles%2F6-antiroll-bars%2528web%2529.jpg&hash=95807d83cf226aa2bbb3e87c76db1741)
![9-caster-camber-kits%28web%29.jpg](/proxy.php?image=http%3A%2F%2Fwww.moddedmicras.co.uk%2Fupload%2Ffiles%2F9-caster-camber-kits%2528web%2529.jpg&hash=2fe29fe2f4221a85983f3dcef215d031)
![11-whitelinekit%28web%29.jpg](/proxy.php?image=http%3A%2F%2Fwww.moddedmicras.co.uk%2Fupload%2Ffiles%2F11-whitelinekit%2528web%2529.jpg&hash=4b7f145701bd33c387f87eaf78ffdf1b)
![18-Gtir-calipers%28web%29.jpg](/proxy.php?image=http%3A%2F%2Fwww.moddedmicras.co.uk%2Fupload%2Ffiles%2F18-Gtir-calipers%2528web%2529.jpg&hash=fa429987a33eef0a54f8f6d161270ccf)
![12-cargtirbreaks%28web%29.jpg](/proxy.php?image=http%3A%2F%2Fwww.moddedmicras.co.uk%2Fupload%2Ffiles%2F12-cargtirbreaks%2528web%2529.jpg&hash=aa24f46ab8cf0de170ab65485a81ccc7)
![21-garage2%28web%29.jpg](/proxy.php?image=http%3A%2F%2Fwww.moddedmicras.co.uk%2Fupload%2Ffiles%2F21-garage2%2528web%2529.jpg&hash=e787e7fe1bab61649397051322c5c117)
view from the rear…
![12-whitelinekitfitted%28web%29.jpg](/proxy.php?image=http%3A%2F%2Fwww.moddedmicras.co.uk%2Fupload%2Ffiles%2F12-whitelinekitfitted%2528web%2529.jpg&hash=6064e625b82e7b8681ee118329dac10d)
![23-whitelinekitfitted-right%28we.jpg](/proxy.php?image=http%3A%2F%2Fwww.moddedmicras.co.uk%2Fupload%2Ffiles%2F23-whitelinekitfitted-right%2528we.jpg&hash=5a4ec55cd2c0bfe0988017e6d743ed31)
![21-arch-clearance%28web%29.jpg](/proxy.php?image=http%3A%2F%2Fwww.moddedmicras.co.uk%2Fupload%2Ffiles%2F21-arch-clearance%2528web%2529.jpg&hash=55cf9c931a771f604cb278a630be2736)
![16-Undercar1%28web%29.jpg](/proxy.php?image=http%3A%2F%2Fwww.moddedmicras.co.uk%2Fupload%2Ffiles%2F16-Undercar1%2528web%2529.jpg&hash=0d0273951c0c1ed22d1e5b01cc2b42bf)
![15-Undercar2%28web%29.jpg](/proxy.php?image=http%3A%2F%2Fwww.moddedmicras.co.uk%2Fupload%2Ffiles%2F15-Undercar2%2528web%2529.jpg&hash=9eb4e9d2b03a85bc5ceaa8cf5138caa5)
![7-Undercar4%28web%29.jpg](/proxy.php?image=http%3A%2F%2Fwww.moddedmicras.co.uk%2Fupload%2Ffiles%2F7-Undercar4%2528web%2529.jpg&hash=df293dd0dec42711b4706f3342f77510)
![17-Undercar5%28web%29.jpg](/proxy.php?image=http%3A%2F%2Fwww.moddedmicras.co.uk%2Fupload%2Ffiles%2F17-Undercar5%2528web%2529.jpg&hash=778951c3eb04968453436e2047b8df84)
![4-UndercarR%28web%29.jpg](/proxy.php?image=http%3A%2F%2Fwww.moddedmicras.co.uk%2Fupload%2Ffiles%2F4-UndercarR%2528web%2529.jpg&hash=6b0b95248e9471af1ae69202d0938e99)
![25-My-car-engine%28web%29.jpg](/proxy.php?image=http%3A%2F%2Fwww.moddedmicras.co.uk%2Fupload%2Ffiles%2F25-My-car-engine%2528web%2529.jpg&hash=8a9d283e9e504e35645c4248ef6c7d3b)
![21-My-car-engine-bay%28web%29.jpg](/proxy.php?image=http%3A%2F%2Fwww.moddedmicras.co.uk%2Fupload%2Ffiles%2F21-My-car-engine-bay%2528web%2529.jpg&hash=8405b4630e2cec2f4f5fb028ab3a0f76)
![26-Image030.jpg](/proxy.php?image=http%3A%2F%2Fwww.moddedmicras.co.uk%2Fupload%2Ffiles%2F26-Image030.jpg&hash=6a194874ade08af0d197a000bbeaa2ce)
![27-Image020.jpg](/proxy.php?image=http%3A%2F%2Fwww.moddedmicras.co.uk%2Fupload%2Ffiles%2F27-Image020.jpg&hash=62d831ca3b48d890ae8efa7219b1bd37)
![29-Image022.jpg](/proxy.php?image=http%3A%2F%2Fwww.moddedmicras.co.uk%2Fupload%2Ffiles%2F29-Image022.jpg&hash=3e8cd7b6842909617bedef5c3b35ce19)
sills replaced…
![5-Image033.jpg](/proxy.php?image=http%3A%2F%2Fwww.moddedmicras.co.uk%2Fupload%2Ffiles%2F5-Image033.jpg&hash=a9650b182ad0b4bb8699ec9a8894fdb8)
![4-Image034.jpg](/proxy.php?image=http%3A%2F%2Fwww.moddedmicras.co.uk%2Fupload%2Ffiles%2F4-Image034.jpg&hash=8cc0e1d407872e1fa3de13157ec6dda8)
![30-Image035.jpg](/proxy.php?image=http%3A%2F%2Fwww.moddedmicras.co.uk%2Fupload%2Ffiles%2F30-Image035.jpg&hash=0a935815ef03c8ffc84f1c8286f8e718)
tread pattern…
![25-Image031.jpg](/proxy.php?image=http%3A%2F%2Fwww.moddedmicras.co.uk%2Fupload%2Ffiles%2F25-Image031.jpg&hash=c9297dd7213663707a522d60ff58d7ca)
Toyo…
![16-Image032.jpg](/proxy.php?image=http%3A%2F%2Fwww.moddedmicras.co.uk%2Fupload%2Ffiles%2F16-Image032.jpg&hash=666cf322091f0c64d63d8a5ba7042574)
![25-Image091.jpg](/proxy.php?image=http%3A%2F%2Fwww.moddedmicras.co.uk%2Fupload%2Ffiles%2F25-Image091.jpg&hash=32b71e18fc03490fa16826eec16e4370)
door handles…
![3-Image090.jpg](/proxy.php?image=http%3A%2F%2Fwww.moddedmicras.co.uk%2Fupload%2Ffiles%2F3-Image090.jpg&hash=9efff0eb70410f971977949460c0cffa)
more…
![9-Image088.jpg](/proxy.php?image=http%3A%2F%2Fwww.moddedmicras.co.uk%2Fupload%2Ffiles%2F9-Image088.jpg&hash=ffc76058a816a3db04c271bac6444151)
![12-Image072.jpg](/proxy.php?image=http%3A%2F%2Fwww.moddedmicras.co.uk%2Fupload%2Ffiles%2F12-Image072.jpg&hash=70246fcbd02b2958eed6df10e67a8229)
![11-Image074.jpg](/proxy.php?image=http%3A%2F%2Fwww.moddedmicras.co.uk%2Fupload%2Ffiles%2F11-Image074.jpg&hash=d338858a7e848ecf14fb627658eb0d44)
![11-Interia.jpg](/proxy.php?image=http%3A%2F%2Fwww.moddedmicras.co.uk%2Fupload%2Ffiles%2F11-Interia.jpg&hash=99167557bd8defec3a59f98137775a29)
![17-Dials.jpg](/proxy.php?image=http%3A%2F%2Fwww.moddedmicras.co.uk%2Fupload%2Ffiles%2F17-Dials.jpg&hash=51072a717e80ecd57b0949e36147eb19)
![23-Image068.jpg](/proxy.php?image=http%3A%2F%2Fwww.moddedmicras.co.uk%2Fupload%2Ffiles%2F23-Image068.jpg&hash=791b50f08a65b625d01d2878dfeb53ad)
![1-Image071.jpg](/proxy.php?image=http%3A%2F%2Fwww.moddedmicras.co.uk%2Fupload%2Ffiles%2F1-Image071.jpg&hash=534f1598f5ce6f9d14ad43fbf0802c95)
![27-Clear%20side%20rep2.jpg](/proxy.php?image=http%3A%2F%2Fwww.moddedmicras.co.uk%2Fupload%2Ffiles%2F27-Clear%2520side%2520rep2.jpg&hash=c45d02f3db652c0ef4ee9830e82d7cfd)
another angle…
![24-Clear%20side4.jpg](/proxy.php?image=http%3A%2F%2Fwww.moddedmicras.co.uk%2Fupload%2Ffiles%2F24-Clear%2520side4.jpg&hash=1b910dbdf123064a2e23fd380856b4d9)
![17-Clear%20side%207.jpg](/proxy.php?image=http%3A%2F%2Fwww.moddedmicras.co.uk%2Fupload%2Ffiles%2F17-Clear%2520side%25207.jpg&hash=d59f6d7502d2c72c1dcd83b71bffe0d7)
![20-Turbo4.jpg](/proxy.php?image=http%3A%2F%2Fwww.moddedmicras.co.uk%2Fupload%2Ffiles%2F20-Turbo4.jpg&hash=7716ced6efc7aff7ca49568deae301a7)
![15-Turbo13.jpg](/proxy.php?image=http%3A%2F%2Fwww.moddedmicras.co.uk%2Fupload%2Ffiles%2F15-Turbo13.jpg&hash=5fb401e653a3bf27e7524e23f96559d4)
![12-Turbo12.jpg](/proxy.php?image=http%3A%2F%2Fwww.moddedmicras.co.uk%2Fupload%2Ffiles%2F12-Turbo12.jpg&hash=37171b3b9bd5e357265eda519ec2b571)
![3-Turbo11.jpg](/proxy.php?image=http%3A%2F%2Fwww.moddedmicras.co.uk%2Fupload%2Ffiles%2F3-Turbo11.jpg&hash=cb684e4586b4c79e294439b0c4087310)
![27-Turbo10.jpg](/proxy.php?image=http%3A%2F%2Fwww.moddedmicras.co.uk%2Fupload%2Ffiles%2F27-Turbo10.jpg&hash=c9b1ad8d86c1f129faf07b446d484bbd)
![8-Turbo9.jpg](/proxy.php?image=http%3A%2F%2Fwww.moddedmicras.co.uk%2Fupload%2Ffiles%2F8-Turbo9.jpg&hash=9d014b68dd89386f55946b5ac256ebba)
![11-Turbo7.jpg](/proxy.php?image=http%3A%2F%2Fwww.moddedmicras.co.uk%2Fupload%2Ffiles%2F11-Turbo7.jpg&hash=f162e14b0a865dae82f428c49c943516)
![15-Turbo6.jpg](/proxy.php?image=http%3A%2F%2Fwww.moddedmicras.co.uk%2Fupload%2Ffiles%2F15-Turbo6.jpg&hash=ede5553da7cc933dfafd5797ee51af3c)
![18-Turbo1.jpg](/proxy.php?image=http%3A%2F%2Fwww.moddedmicras.co.uk%2Fupload%2Ffiles%2F18-Turbo1.jpg&hash=0482b19536040cb68bf1e8195baaf66f)
![20-Turbo3.jpg](/proxy.php?image=http%3A%2F%2Fwww.moddedmicras.co.uk%2Fupload%2Ffiles%2F20-Turbo3.jpg&hash=a6ba026c7fa4b1ac5e04e311ad1fe762)
![21-Turbo5.jpg](/proxy.php?image=http%3A%2F%2Fwww.moddedmicras.co.uk%2Fupload%2Ffiles%2F21-Turbo5.jpg&hash=e7434e28afdc853c0cb5124cb1979649)
![5-Turbo2.jpg](/proxy.php?image=http%3A%2F%2Fwww.moddedmicras.co.uk%2Fupload%2Ffiles%2F5-Turbo2.jpg&hash=0749cefa2e28b9f2021c12ba21cb9c36)
Dave’s Nissan Micra Turbo
Engine:
CA13DE 1275cc
Turbo: Garret T2
Janspeed De-cat
Injector harness
Ignition harness
Pressure sensor
Suspension:
Wheels:
Tyres:
Breaks:
Standard Gtir Disks
[FONT="]
[/FONT] Exterior:
Interior:
ICE:
To be fitted…
To be continued...
