you mean when the carbs are connected to the manifold they should be level accross the top of the carbs them selves? use of a spirit level?Throttle cable just used the micras standard cable
When making the manifold make sure the float bowls on the carbs are at the right level
Another thought for you, if your a fan of having petrol in your tank it won't last long on carbs
well i start work in 2 weeks and every day ill be driving 4 miles in total until weekend so it wont really matter to me during the weeks , also this is how im getting my money to do it haha
There wouldn't be much point in going ITB without having a decent exhaust system, and CG's power tends to tail off near the limiter anyway unless its been built as a screemer so I don't see much point removing the limiter tbhassuming ive fitted a decent 421 mani, some 1.0 flattop pistons and meddled with the rev limiter, what kind of power would you expect to see from running bike carbs on a ghetto level? move than youd see from the proposed itb on the standard ecu setup?
i was going full screamer, fabricate mad side exit, lightend fly, super high comp, barrel grinder porting, home made copper core leads to massive gap plugs. its not going to be used for anything more than track days/ hillclimb if i can get the time/keep my job.(work for bae portsmouth, all is not well atm lols)There wouldn't be much point in going ITB without having a decent exhaust system, and CG's power tends to tail off near the limiter anyway unless its been built as a screemer so I don't see much point removing the limiter tbh
Rough guesstimate 115bhp?
Hope all goes well on the job front matei was going full screamer, fabricate mad side exit, lightend fly, super high comp, barrel grinder porting, home made copper core leads to massive gap plugs. its not going to be used for anything more than track days/ hillclimb if i can get the time/keep my job.(work for bae portsmouth, all is not well atm lols)
thanksHope all goes well on the job front mate
Short block wise yes, different cams between 1.0 and 1.3/1.4If I'm reading it right ( I've had a few beers) then a 1.0 with a 1.3 crank or a 1.3 with1.0 pistons will be the exact same thing.
aye, it has longer rods1.0 doesn't have a shorter block...
11.5 ish chopsoh man my head hurts now lol. ok that clears that up. what sort of compression ratio and power hike does the 1.0 pistons and rods/1.3 crank give?
just another quick question, would bike carbs be able for a turbo? i know to make a turbo work with them id have to fabricate a box with 4 holes for the plenums so the forced air can be sucked if that makes sense?
like this
http://img189.imageshack.us/img189/7258/user20520pic26712616786.jpg
