Im about to start building the exhaust manifolds for my turbo conversion in my mini clubman. I've already got the inlet manifold and bigger injectors sorted.
The plan was to use the currently fitted cga3 1348cc engine in stock form and run 4psi - 7psi with the GT1752.
However I'm a little concerned the coilpack piston ring lands and crown height don't seem as forgiving as the standard pistons in the cg13's. I'm a best sticking with the cg13?
I'm running DTA ecu so no difference in installation.
I'd appreciate your thoughts
