I too need help Serial Number 7478220Hi, try 9318 or 1318.....
Device Number 7612830091
Date 10.11.17
Hi,Hi
I also need help
Serial 0954471
Device 7612830023
Date 09.08.12
Thank you for the responseHi,
No help possible for this LCN radio.
You can find the code at the dealer.
Hi i have nissan micra 54 plate radio number is BP334947305173 any ideas for code .thanksHi, try 9337 or 1337........
Hello,Hi i have nissan micra 54 plate radio number is BP334947305173 any ideas for code .thanks
Try 5202 or 1202.....
Hi, can you please also tell my radio code. I have Nissan Micra 2004. Serial number is: BP334936381636.Hello,
The battery recently went flat on my 2006 Nissan Micra. I have removed the radio to get the serial number:
Blaupunkt-Werke-GMBH
BP5387 6 9679245
It would be amazing if someone could send me the code for this!
Many thanks
G
Hey do you have the code for CM0023A3139266 please ?Try 5202 or 1202.....
Hi. Can I get code for my radio please? Serial: DW49N07338Try 5202 or 1202.....
Hi all,
This thread had gone a bit quiet so resorted to a paid solution.
This company was best out of all the research I did. £4.99 and code instantly provided. Just needed the BP number and 10 digit serial number.
Thought I'd share incase anyone else finds it useful.
Instant Radio Unlock Codes For Just £4.99
The cheapest, fastest radio code generator around. Use our simple easy-to-follow guides to get back into your radio in minutes.www.rapidradiocodes.co.uk
Hi, try 9615 or 1615Hello! Can anyone help me retrieve the code for my micra radio.
BP334947298619
7 643 349 318
Thank you!
Hi, try 2257 or 0257....Hi, could anyone help me please with a radio code on my 2009 Micra?
Serial no:BP7383 9 8785864
Thank you.
Hi, try 3322 or 1322.....Hi any possible code for bp334947308774
Many thanks
Apologies it isHi I need help getting a radio code for
BP 5362 5842243
Hi try 8332 or 0332.....Hello not sure if anyone read this but please need help to get the code for bp536258422434
Thanks will give it a try issue is its stuck on wait 1 hour for a few days. And out of the 2 codes if 1. Is wrong how much longer will the timer become on the radio safe lockHi try 8332 or 0332.....
The 'wait one hour' message goes away after an hour WITH the radio turned on and the ignition on, so go for a drive and it should reset...Thanks will give it a try issue is its stuck on wait 1 hour for a few days. And out of the 2 codes if 1. Is wrong how much longer will the timer become on the radio safe lock
Hi John. I don't suppose you'd be able to suggest one for my newly-acquired '14 micra, please? It's DW3BN04251. Thanks in advance.The 'wait one hour' message goes away after an hour WITH the radio turned on and the ignition on, so go for a drive and it should reset...
