jabran200
I am contempalting on what max boost i should tune my car too, i was considering 8 psi as a sensible point but I want it to be mroe around 11-12 psi. Is that doable on stock internals? I have the emanage for additional fueling and igniton and the knock sensor wired up to my radios aux for easy knock sensing.
Whats the max someone run reliably on the stock internals? I jsut want the most out of it as i can, It's still the stock cg10de so if it blows and a cg13de will go in, it blows but this is the auto block so it is stronger from what i have heard.
can't wait as this weeked/early next week the turbo setup will be tottally fitted and will be read for tuning.
Jabran.
Jabran.
