Hi all, I'm new here but i've just got my second micra, a 1998 1L shape, (the first having been written off by some #### in a stolen car), and i'm trying to fix the AMAZING bodge job that was done to the stereo wiring.
both the existing stereo and the dash wiring had been cut and taped, so i can't just do the smart thing and buy an adapter. in addition, the "professional" who fitted the stereo wired in a new power supply directly off the battery. and the blue and red wire has been ON FIRE.
i've found this post: http://micrasportsclub.net/showthread.php?t=30906&highlight=stereo which lists the wire colours as follows:
--POWER---
-Blue with Black Stripe = ACC 12V (ignition power)
-Red with Black Stripe = Constant 12V (if your stereo doesnt have a fuse on its Constant 12V wire, BUY ONE!)
-Red with Blue Stripe = Illumination wire
-Black = Ground (although I suggest you use your own, or multiple ground points)
--FRONT SPEAKERS--
RIGHT: Brown wire and Black with Red stripe (Positive/negative unknown)
LEFT: Blue wire and Black with White Stripe (Positive/negative unknown)
You will notice that there are TWO Black wires with red stripes. To test which one is the speaker and which one is the power wire, get yourself a fully charged AA battery and put the BROWN wire on one end of the battery and one of the Black with Red stripe wires on the other side of the battery. When you get the right wire the right hand speaker will make clicking noises.
According to the Haynes Manual, all K11 have front speaker crossovers somewhere in the dash. These crossovers (most likely very simple units) are for the optional A-Pillar tweeter which came in many higher grade models, in Australia this being fully optioned Series 2 SLX and all Series 2 Super S. For optimal sound quality, I highly recommend running your own wires for the front speakers as the standard series 2 equipment is rather lacking.
--REAR SPEAKERS--
RIGHT: Red with Black stripe and Black with Pink stripe (positive/negative unknown)
LEFT: Black with Yellow stripe and Red with Yellow stripe (positive and negative unknown)
(Thanks to a Member of the Micra.au club, Yom.)
can anyone confirm those are correct? the colours seem to match what i have coming out of the dash, which is better than most of the charts i've found!
i'm just going to replace the wire that has been on fire, wire in an ISO adapter, and connect up my own Alpine head unit and use that battery power feed for the amp for my subwoofer... IF i can sort out which wire is which without doing myself, the car, or the stereo an injury.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
thanks for any help!
--POWER---
--FRONT SPEAKERS--
--REAR SPEAKERS--
