It's all in the steering.. Brakes are good and free.. If you take hand off the steering wheel it pulls to the left as driving.. Camber of the road doesn't change it.. Tyres have been rotated to eliminate tyre pull.. Its not harsh but you have to hold the steering wheel to keep it going straightCould it be a jammed brake caliper?
Can't you give us more info?
Enviado do meu MI 8 através do Tapatalk
Cheers for the reply.. Yeh we have a mixture of all 3 setups...cheers will have a look at that area againIm not sure if the k11 is different there but here in Europe and UK they dont have electronic power steering. Id start with checking suspension. Mine pulled to the right because of a very worn tyre (1mm vs 6mm on the other tyres) due to a worn out shock.
Cheers.. Will give that a go... Its sort of my train of thoughts was headingI'm only going off experience with my sister's i30 but it'll have a sensor to detect steering position on the steering column, if this is out of sync then it's likely to provide assistance to turn the direction it thinks you are wanting to go, if that makes sense.
After I replaced a steering dampener on the i30 the mechanic recalibrated it for me as relative positions had changed. Maybe yours needs recalibrating?
Hey. Sorry I’m the K12 EPS Person.Hi I have a k11 with eps fault.. No fault codes or light.. Pulls to the left badly but wheel alignment is good had it checked.. Anyone know where to start looking.. I'm in new Zealand and help is pretty thin down here without spending a futune.. @huttojb I'm told you the go to man.. Cheers
No worries. CheersHey. Sorry I’m the K12 EPS Person.
OK..cheers for that.. Gonna have to investigate further ?K12 have a different steering concept. The eps is a all in one system. The torque sensor, motor and control is in one assembly where I think the K11 is separate components
Hello mate. 4 years later I have the same issue on mine. Have you recalibrated it? If so did it solve the problem?OK..cheers for that.. Gonna have to investigate further ?
