Undo the splash guard and turn it out of the way to gain access to the hose clamp to drain the coolant. It's not old so I'll reuse it.
Sent from my WAS-LX1A using Tapatalk
![41776881651_9e67e0bcbc_c.jpg](https://farm1.staticflickr.com/973/41776881651_9e67e0bcbc_c.jpg)
Haha. Unbelievable what ppl will do eh!One of my cars had in the past had a bump and the repairer must have snapped a bolt so they actually just glued the bolt head back in place during the repair!
Hi, sorry to ask a Noob question but, does this come out of a K11 and if so, which one?Now I don't know about you lot out there, but I like to know what revs I'm doing. Not for any real reason other than interest.
So stuck one of the Rev Counter clocks in.
Looks much better aesthetically.
Five dashboard screws later and its fitted.
I think it was only the Si model that has green clocks for a faceliftI don't know specifically which k11 model the green clocks come from. It'll probably be something like the SR. You can get the standard black rev counter clocks from any of the higher spec facelift Micras such as GX, SE, etc.
Thank you, will head off to the scrappy near us.I don't know specifically which k11 model the green clocks come from. It'll probably be something like the SR. You can get the standard black rev counter clocks from any of the higher spec facelift Micras such as GX, SE, etc.
TY! Rather have the black one if they have the rev counter like that?I think it was only the Si model that has green clocks for a facelift
Sent from my SM-G903F using Micra Sports Club mobile app
Well crap, I snapped all four of the slam panel bolts during my engine swap. Will try your method next time I have to undo something. There are many snappy bolts on mine.So now to remove the slam panel. The bolts were rusty so took a while, kept screwing them out and in little bits at a time so they wouldn't snap. Had run out of WD40. The two front support bolts just below the bonnet catch were easy to remove as they were covered in grease
Undo the top hose, unclip the fan connector, and lift the rad out.
Which model did these come from?So not content with my original electric mirrors I decided to buy these ones that fold in also.
Think they came from a Z10 Cube.
No problem, but you're best off posting them in the sales area or on the Facebook page.I've got a pair of cube electric mirrors if anyone is interested, soz for hijacking.
I decided that as all my interior is blue along with the electronic stuff, that I'd fit blue leds to the dash. First attempt. There's not enough light spread to light up the needles properly and also the resistors that are fitted are to small in value. The leds kept failing after about a week or two.
So after a rethink I fitted white leds (which are closer to the blue spectrum than normal filament bulbs) in blue holders with the correct value resistors (620ohms).
Much better. You can't tell from the photo very well as the camera corrects the blue hue somewhat. But suffice to say it's better and blue.
Too funny! I found one of these 2 days ago and could not figure out where it was meant to go, now I know!It was never designed for mine so the wiper cutout doesn't line up.
I'm going to get the body shop to fill it and make it flush before spraying it up.
here perhapsToo funny! I found one of these 2 days ago and could not figure out where it was meant to go, now I know!
