Update on no engine management light
Hi on further investigation it looks as if the bulb for the engine management light is missing! (Am I right?) if so can this be replaced or do I need a whole new unit? Thanks for any advice
Quote; “Hi my 2014 Micra failed its test because of an emissions fault which is now cured and all codes cleared. The technician however has now failed it because there is no engine management light even on start-up”.
May I suggest that your above earlier post implies that above engine management lamp was working prior to the emissions issues?
Your well improvised picture appears to show multiple pinhead sized LED lamps in place as expected & unless the specific LED has been unsoldered excised from the PCB, & that is unlikely. No old style MES light bulbs anywhere in your picture.
Perhaps it would be advisable to get it to a auto electronics/electrician mobile repairer or to a Nissan specialist, both of which maybe much cheaper than Nissan main dealers on comparing their hourly rates & or quotes?
Good luck :)
