The rear Nissan fog/reverse lights on this Nissan K11 2001 are not working properly, one light turns on for fog mode, and one light on for reverse mode using the same bulb the light turns on and off from opposite ends.
* Both Bulbs have been checked and the filament is fine and no burning found at the bottom of bulbs or circuits.
* Interior Fuses have been checked and tested using circuit tester.
* Engine bay fuses all checked and working fine.
* Wiring to the lighting has been checked and isn't burned or cut.
I'v had problems with this micra in the past and managed to overcome them from steering problems to engine hesitation but this one is quite tricky. PLEASE HELP. Thankyou
