jamier2007
Fused*
Sent from my Nexus 4 using Tapatalk
relays only work for all the 4 injectors, and 2 fuses are good,Fused*
+1, injector plugs 1,2 and 3 exit the loom in a row, and #4 plug exits the main harness further down, you must have a wiring fault azzyThen it short circuits some where...
Thank god found the fault after hours of looking for wat it can be and tested both ecu but same voltage, tested the 4th injector for any breaks in both wires but nothing, so test from the ecu where the 4th injector goes in which is yellow and blue wire, and seems to show 12ohm which is same as doing it from top on the injectors means no break in any wires? So now i tested for live wire as @frank said for each injectors with ign on I found all the 4 are live, so they all working wires, and now my only clue was ??? ?? Open the main wrap which is on the injectors and found this like @frank said it's all in one+1, injector plugs 1,2 and 3 exit the loom in a row, and #4 plug exits the main harness further down, you must have a wiring fault azzy
no mate coz I tryed both ways on wire and both poped on the spare injector it was ok no pops, leaving me with a faulty inejctorYou got to plug it in correct azzy
I have tryed too unscrew it while on mani and off the mani still very tight ?Well done for keeping at this! Glad you found the fault
Injector screw are a pita eh. I find you can get more force behind it when the rail is in the mani
Thanks I will try thatRemove the rail and a pair of good quality mole grips will have the screws out, and use new allen bolts to replace the knackered screws.
I got a hammer drillOr try one of these (also works well for stubborn can cover bolts) http://www.sealantsandtoolsdirect.c..._P24427.html?gclid=CL-99NC89r4CFSEewwodOJcAow
No, don't use thatI got a hammer drill
Sent from my iPhone using T
I mean a 18v battery one only on slow speedNo, don't use that
Oh.. I thought you meant like an SDS. Err. Could give it a go the one I posted you can get everywhere pretty cheap though and are handy for lots of jobs.I mean a 18v battery one only on slow speed
No I have 3 types of drills but for this job I'll try and give it a go on 18v drill,Oh.. I thought you meant like an SDS. Err. Could give it a go the one I posted you can get everywhere pretty cheap though and are handy for lots of jobs.
I just bought all 3 for DIY at home jobs and car jobs, and other one is tourqe wrench,Thats nice. I bought one that does everything lol.
And the award for helpful comment of the day goes to...Thats nice. I bought one that does everything lol.
Lol, my helpful comments are just as effective though...And the award for helpful comment of the day goes to...
not even a little bit true!Lol, my helpful comments are just as effective though...
No bads wires to it ? I have a full wiring loom going in this week, I also thought about all the money gone into it I won't wana sell it, but many members have help, and I don't think u will find a fault with my car when am done with it, no rust no limp modes, no oil leaks or smokes, I will make it a 1 year project after am done with itive just read the last 4 pages and kicked my dog,,,,,,,,azzy you owe my dog a bone!!!!
il be honest though,,some people might not understand this but reading this thread makes a refreshing change from all the other car,bike,scooter,buggy build threads ive followed and done myself over the years
some threads i read you can tell when people are telling porkys or have just paid out for work and take the glory,,,,,,,,azzy,,your not mechanically minded but have taken on a major task,,,dont get me wrong you would be lost if it wasnt for this forum but its good to see you at it,,,even though its been up for sale 10 times and its been turned into a death trap its good to see all the small crappy jobs being documented and talked about
all that said,,,,,,,,,,please dont sell this car complete after youve taken it apart and messed with the wiring,,,unless you tell them everything and show them this thread,,,,you would be putting other lifes in danger doing so
The car idles at 1k rpm on warm and after 5 mins it will cut out when I rev the car it will hold it and without gas it will cut outIs the idle set too low? 1k rpm will be the cold enrichment time for 5 mins. Then it drops down to about 700-750 when it's warm. It just stalls doesn't really give us much to go on.
Can it be I need to adjust the idle screw a bit up ?Sounds like bad idle speed to me.
No bads wires to it ? I don't think u will find a fault with my car when am done with it, no rust no limp modes, no oil leaks or smokes
Thanks for the comments that's with everything on msc and other car builders no car is perfect or qualified, and people who don't post there car faults and other problems are hiding something, am atleast showing my build and telling people about my build good or bad, am only being honest, learning from scraps made me save 1000s on my other cars, and didn't see a mechainc from till now, am not hiding like others do, if u have a oil leak I'll say I do, if u have road tax say the dates like 06/06/2014 be clear, coz I amno offence meant in my post mate,,iam just being brutally honest,,,its not about finding rust,smokes or limp leaks at the end of it,,,,its worrying if all the nuts,bolts,washers and connectors are fitted correctly
its like getting a hairdresser to fit your gas boiler,,,,,,,would you trust the work and let your kids sleep inside?
or letting the paperboy re-wire your house,,,,,would you feel safe?
then you come to sell your house to a young family,,,two weeks later there all dead because the fuse board blew up which ignited the gas leak
same goes for your car mate,,,,its all good that your having a good time and learning alot but please dont forget your building a road car,which you keep wanting to sell,,,,,,road car means,,kids,pedestrians,old people,other motorists
U can't judge from post and pictures my car looks complete brand new with all parts fitted in the same way as manual says, u have to come and see the car in real life and tell me what is wrong and I'll prove the fact it's all done in orders no short cuts,Not trying to sound like a prick but theres MSC standard which isnt that great anyway except for a few guys on here (no offense to you lot) and then there is your standard.
I have done bad/bodgey things to cars but thats all bodywork or something which cant kill you. Your standard seems shockingly low azzy and your lack of knowledge gives me the belief you can make a life threatening mistake like not putting splitpins back in etc.
I am judging by your lack of knowledge... You seem to take peoples very good advise and chuck it back in there face. I sat back for awhile and watching but its just getting annoying now azzy.U can't judge from post and pictures my car looks complete brand new with all parts fitted in the same way as manual says, u have to come and see the car in real life and tell me what is wrong and I'll prove the fact it's all done in orders no short cuts,
am gona take my time why ? coz am busy workin, I have more cars to only think about this micra, I have other problems on cars I fix, it's not a days build and think yeh plug the key in and drive, for me am taking other good advice from ppl who has told me many things and got this running, I do note things and leave for a day am free on, something's I even do I don't even post on here,I am judging by your lack of knowledge... You seem to take peoples very good advise and chuck it back in there face. I sat back for awhile and watching but its just getting annoying now azzy.
I want you to be able to prove us wrong that you can make this car but still by the seems of things this is another doomed turbo project from the start.
let's put a bet everyone it will be done without me even coming on msc and showin off[quo te="Huggy444, post: 687547, member: 15328"]Least you've worked your way through it, just want to see it finished
Sorry no comments am on my bet deal with everyone on msc who said it will never be finshedThis thread could be one of a number of reason someone just got a k11
you should have got that $10 code reader from abroad azzyman
It would be so much less colourful on here without you Azzy. Keep us updated!
Sorry no comments am on my bet deal with everyone on msc who said it will never be finshedSent from my iPhone using T
Sorry I will only update when am doneIt would be so much less colourful on here without you Azzy. Keep us updated!
My bet is who didn't think I will do it I will prove the ppl wrong and have a Micra turbo on the roadi didnt see anyone bet you.or am i wrong
let me prove my point then ppl can comment about me afterthats crazy .people needs are need to be proved wrong.
You must be furious at the "who didnt think I can do it" crowd.
and even though i think no one actually bet you --- get the heck on with it.
think of it this way...no one here would lose only you if you give up
32 pages
You've said this before.Sorry I will only update when am done
