PollyMobiles Rebuild
2025-10-30 Weld Rear Corner Rust
To repair the rust hole above the fuel filler pipe I first need to drain the tank
Syphoned out 7.5L (just as the low fuel light appeared)
Tank has tiny little specks of dirt (not as much as last February)
Filling up at local morrisons for the past few months still contains some black debris but not as much as when I used to fill with tesco fuel 👀
With fuel drained I can remove the filler pipe for better access to the rust area
Wirebrushed the surface rust off this area
Gave the stainless pipe a quick polish too 😁
Chopped this triangle section out
Next day I'll be welding a new section in and repaint it with polyurethane coat before tackling the other rust hole in the wheel well
2025-11-05 Lidl Powerbank / Compressor
My old tyre pump was worn out with cracked rubber hoses and saw Lidl selling this 4in1 powerbank/jump starter/light/digital tyre pump for £45 which seems really handy for kassandra :cool:
Works gr8 at conveniently & quickly pumping the tyres upto the target pressure before turning off automatically, plus it doesn't need plugging into the car (no hassle with wires) and no need to run the engine
ofc I was curious to inspect the insides 😅
Battery label says
model: F8043126
voltage: 12.8v
capacity: 3500mAh 44.8Wh
date: 2025.02.20 2501
serial: 41PpP9/44/129
material: LiFePO4
I finally added some rubber cushions on the garage walls to protect the door edges
These old bosch super plus wuper blades I brought from halfords has lasted 2yrs and now starting to smear, which lasted twice as long as all previous cheap ones, so I replaced them with a new set :cool:
2025-11-06 Prep Peugeot 307 for MOT
With the peugeots MOT coming up, I checked over the car.
The plastic headlight covers were a little faded over so I sanded with 1200 & 2500 before buffing with G3 & polish :cool:
Wirebrushed the decades of caked brake dust off the wheels
The only tiny thing to fix is a rust hole in the inner rear sill
2025-11-07 Weld Peugeot Sills & Boot Floor
Wirebrushing the rear left sills reveal more holes as a result from years of parking outside the house with the car leaning to the left & rear 👀
Easy enough to patch over
Painted with epoxy primer
The drain hole in the wheel well also rotted
Chopped the rot
Patched
Painted
Book the MOT in the coming days 🤞
2025-11-10 Replace Peugeot 307 Spark Plugs & MOT
With the MOT coming up & the old plugs slightly worn, I ordered a fresh set of NGK LFR6B on ebay for £12.80
New plugs are gapped too tight at 0.8mm so I adjusted them to the oem 0.9mm and quickly swapped them over in the morning while it stopped raining before heading off to work.
With fresh plugs, the cold engine fires up much faster
Inspecting the old plugs, they're in the perfect heat range
Next day the Peugeot went for it's MOT and passed with zero issues 🥳😇
2025-11-12 Washing With Rain Water
In my new garage roofing, all the rain water collects & drains into these three 45L bins I recently added, which can be used around the house to save water (ie water the plants, flush toilets, wash cars etc)
Usually I wash the cars with a garden hose but today I decided to wash kassandra with the 3 bucket method using the 130L of free rain water collected from last nights heavy rainfall
& the result of using fresh rain water compared to "hard tap water" is no more streaks or dried water spots on the glass or paint 😎
I should've done this yrs ago 😅
Many thanks for the reminder.
In 51 years driving, I never thought of harvesting rainwater until I got a water meter to save about £400 a year off my water bill. "D'oh!"
Wrote it off to experience, hey ho. :rolleyes:
Wow that's a huge saving.
My family house has been paying a fixed rate £400 per year for unmetered water (cos it used to be a takeaway shop) but this year it shot up to £500 😬😥
Debating whether to have metered water in hopes of saving money incase we've use less water than estimated by the standard fixed charge, but my sister said best try stay unmetered cos her metered water bills for just 2ppl is alot higher than ours 👀
My metered water bill is now around £300 a year (just me in the house), like everyone it has almost doubled in cost over the last few years, also more than 50% of my bill is surface water drainage, even though the house was built with no surface water entering the drains, there's nothing I can do about that unless I have an industry standard and inspected (every year) soak-away fitted, even then they still charge you for the drainage on the roads, well at least here they do.
My yearly consumption is around 24 meters/squared, and with the fresh and dirty water being under 50% of my bill there's limited scope for me to have much impact on my bill, I'm already considered a very low user, so I can see higher consumption households being worse off with a meter.
Yeah me mom & dad live in two joined terraced houses and our sewage charge is about 56% of the bill.
For the past few years both the supply & drainage has been rising £10/yr but in 2025 they suddenly shot up by £50 🫣
So if you're paying approx £150 for light consumption of metered water yourself whereas I'm paying like £200 unmetered water for 3 of us
(we're probably medium consumption cos mom waters lots of plants around the house daily, we shower/bath daily & me washing both cars occasionally. all of which the collected rain water system will help with)
I think it's safer to stay unmetered inho 😅
2025-11-13 Fix Peugeot 307 Leaking Boot Handle
It's been raining hard overnight and once again this morning there's a little pool of water in the spare wheel well
According to this Peugeot forum post, it's a very common issue with leaking past the boot handle
https://www.peugeotforums.com/threads/307-boot-leak-fix.208666/
And looking at mine, yup it's leaking past the handle/switch.
Both 10mm nuts were also abit loose? :unsure:
I'm thinking 20yrs of yanking the boot handle up has gradually loosened these 2 unsecure nuts until the old gasket was too loose to seal
Also just look at this silly paper-thin rubber gasket, no wonder it leaked :rolleyes:
Not much rubber material at the top/bottom to keep rain away from the openings. It's also been crushed down to a wafer-thin 0.20mm 🤏
Made a new bigger gasket out of some Marygold glove which was 0.4mm thick 🤪
Also added a smear of grease to further seal around the gaps and keep it dry from now on 🤞
In Devon unmetered domestic water charges were & are related & proportional to the old rateable values/council tax rates inflation adjusted.
Bigger or more valuable domestic homes come with higher fixed price unmetered water charges?
With a water meter I can control consumption too minimise charges & have made big savings compared to what I was paying with fixed unmetered water rates.
I note you state your family home was a trade take away business & thus may still be subject to trade water rates & that a domestic tariff water meter may achieve a cost saving?
Domestic water meter installation was free of charge & I could kick myself for not doing it years ago. "D'oh!"
Good luck. ;)
