K11 Driveshaft Boots same as K10 ST??
smidge
Small Car Enthusiast
Site Supporter
see subject!
would rather buy k11 ones if they are the same size than buy the universal size ones
smidge, the pre98 1.0 k11 outer joint is smaller (same as the k10) but yours may be bigger still (bluebird ?)
universal it is then!
actually i'll pop one off and measure it up see if i can get similar at the shops
doesn't everyone else pop one off when they change their boots?
i just wish i broke CV boots more often, gets kinda boring
that was an..
extrememly
unenjoyable
job
messy and PITA to get to everything
luckily i had the right sized boot in the garage already from my subaru days!
will see how long it holds up for
im surprised the drivers side one doesn't go first as its right above the exhaust
also i reused my gearbox oil, strained it and it was pretty clean so here's hoping i don't blow the gearbox cause of it
bluebird 1.8 FWD should be the same I would have thought...
not sure we get the 1.8 blue bird stuff here, only ET pulsar or cherry as you guys know it
