Simple job mate.
theyre T-5mm wedge sockets. I replaced mine a few weeks ago with LED's and made a huge difference.
Easy to get to the cluster too.
* under the light dimmer is a screw, remove that and also the steering column covers.
* You'll then have one screw left that is holding the surround on (on the opposite side of the dimmer and up a bit.
* remove the surround and disconnect the dimmer plug and you should be right getting access to the globes from behind if you have small enuf hands..
if not just unscrew it and remove the speedo cable from the back of the cluster to lift it out (along with removing the connectors too)
