Electromagnetic bushes
Hi does anybody know what symptoms this would produce
OP
OP
K
Have cleaned them up, the short one was jammed and now moves on its spring . Noticed it was about 10 mm shorter than the other still . Put them back in (doh didn't check the wear limit but pretty sure there were none ) would it have worn past them ? . Had a slight improvement. Considering the amount of crud on the do you think the electromagnetic powder could be contaminated?
Thanks Kevin
Thanks Kevin
Unlikely from the carbon brushes?
