bumper
This is possible but you may need to test fit and if the fittings are different you might have to change or mod them to suit the car.
Was going to put a sport front on with fogs and then decided that I would stick with the standard on the 2005 model.
You should check out the fixing points and see if they will loosen easy or if you will have trouble with them.
I decided with mine that they were going to be a pain.
If they will loosen off easy you should be able to manage swapping bumper over without much trouble.
Finding a decent bumper in good condition will probably be more of a challenge. Chimney U nuts are what you will most likely require to renew in the process.
Those and the plastic bumper clips that join the front part to the wing as these sometimes break off due to being brittle
