A question about Rocker Covers and Grills
capnmchl
Right, easy one first:
I assume so, but best to double check. The CG10 and CG13 both use the same rocker cover?
Next one:
How difficult is it to open mouth a pre facelift grill? Has anyone tried it?
Yes
Next one:
If you can use fiberglass and body filler then rather easy, just cut it out, i done it roughly with sime tape and then fiberglassed it, then sanded down and filled with body filler. Was quite easy.
Sweet.
That's what I was thinking. Cutting out that whole middle section + the grilly bits with a saw, and then refinish it with fiberglass, fille and sandpaper.
