'95 k11 Micra starts immediately when cold but trouble starting again when recently driven
Whenever I start my Micra after it's been sitting all night it starts perfectly fine, but when I for example go to the gym for an hour and try to start the car it takes a good amount of cranking before it eventually starts. When it finally starts it's like it needs a few seconds to run, almost like it's clogged up and the clog is being pushed out the exhaust. After a tough start like this it's also been drowned in fuel and the fumes tend to give me some dizziness. Anyways, my guess is that the car thinks it's starting entirely from cold and thus feeds more fuel then it actually needs thus drowning my poor micra.
What I've tried:
- Throttle body mass airflow resolder, didn't make any improvement sadly.
- I also bought an IAT sensor that is supposed to fit but so far I haven't found where it would go.
Anyone got any ideas on how to sort things out? Fuel economy is also a little higher than should be.
I would check:
  1. idle air control valve
  2. fuel pump
  3. ECU coolant temperature sensor
I had similar issues with mine, unfortunately I got rid of it before I could change the fuel pump.
