12V/ Lighter fuse
SplanK
Site Supporter
Tried looking through the service manual and this is as much as I got! The fuse itself will be in the fuse panel which is on left side of the dash. Open the passenger door and there will be an access panel where you can access the fuses. There should be a fuse map on the rear of the cover to guide you, but as in the image, it should be a 15a fuse.
