773 Rally cam Spec Nissan Micra
Timing Data
Duration V/L V/C F/L LATDC
Inlet Open 26 BTDC Close 58 ABDC 264 9.09mm 0.210mm 106 1.70mm
Exhaust Open 58 BBDC Close 26 ATDC 264 9.04mm 0.254mm 106 1.65mm
Rocker Ratio = 1.00 : 1
Overlap = 52 Deg
Timing = Valve timing figures, measured in crank degrees
Duration = Total duration, measured in crank degrees at end of ramp
VL = Valve lift measure in mm
FL = Valve full lift measured in crank degrees ATDC inlet, BTDC exhaust.
LATDC = Valve lift at top dead centre measured in mm
I hope this makes sense, I can not seem to line up the headings e.g VL, FL etc.
These cams are being used in rally cars producing 130bhp + on single mass air flow meters.
